Is the cruise control vacum based???
Once again the cruise on my car is not working. It sets but the speed falls off fast. The acceleration trys but does not work at all. Had this happen once on an Ford a few years ago and it turned out to be a vacum leak does this sound possible on the 8?
Brent
Brent
Yes, it's a vacum system
It only has a few components that are under vacum. They are:
1 - Actuator with membrane
2 - Brake vent valve
3 - Clutch vent valve
4 - Vacuum hose T-connector
5 - Vacuum pump
Here's where they are:
<img src="http://www.audipages.com/images/cruisecontrol1.gif">
The vacuum pump is in the front fender under the ABS pump.
You could have a leak, there is also a dump valve at the brake pedal. My old 91 200q would work on and off, the vacuum pump would get water in it.
pw
5 - Vacuum pump
pw
nlybarge
03-17-2012 09:10 AM
Fuzzbeaner
Audi 100 / A6 (C4 Platform)
02-18-2005 01:56 PM
RxFX101
03-01-2004 04:16 PM
YucatanAudi
10-08-2003 06:30 AM
