Issues after Forge DV-R Valve install
Hi all,
On my TTC 225, since I put a black Forge DV-R, I met this problem on my VAG COM :
1 Faults Found:
17608 - Boost Pressure Control Valve (N249): Mechanical Malfunction
P1200 - 35-10 - - - Intermittent
I've also a new noïse when I change speed manually, a kind of noïse of original failed valve. Is it normal ?
When I put the OEM one, I've no errors.
Any help please ?
Thx in advance
1 Faults Found:
Any help please ?
Thx in advance
My point is why move to the DVr if the stocker works fine?
Unless there is some amazing result I'm missing it just isn't worth the bother and cost IMO. If I had a DV fail today I'de spend the $35-45 on a replacement Bosch DV.
I won't say you are wrong but maybe the performance gains are really more anecdotal than anything...
on an otherwise stock rig. Mind you I've not tried any other DVs and have run the Bosch since 2000 on my chipped 180 without any problems whatsoever.
Re: 20,000 miles with APR stage II and stock DV is fine!!!!
But you don't finally answer to my questions ?
1 Faults Found:
1 Faults Found:
Was the original valve failing is the question?....It does make noise normally.....
such as lifting off the throttle at mid-higher rpms. If it's a slight whoosh it's normal. If it's honking or fluttering maybe it failed.
