Ground wire to boost control valve caused problem/problems
Old 07-08-2001, 11:17 AM
Jim TT's Avatar
Default Ground wire to boost control valve caused problem/problems
I fixed my cars lack of power by redoing the ground wire to the boost control valve (I have read about some of you having the same problem). This is a light weight wire and can be broken if not careful when changing the DV valve as the boost control valve is located near the DV valve. I will take a picture later and repost some detials. The fault codes that come up are 17956: boost pressure control valve open, and 17536: long trem fuel mult. system lean. The car has no power when this happens although it is not bad just driving arround at normal speeds. If you think your car has lost power you should check this, the wire will look fine but can break inside the connector. The car was into Audi three times, the first time they changed the BC valve, the 2nd time the DV cvalve ( I knew that was not the problem) and the third time they re did the ground wire Connector except their repare only lasted two days. When I re did the work, this time soldering the wires where they had used crimp connectors, the problem was fixed. What's more I told them to check the ground wire the first time around because I had read about the problem here. Finally they lost one of the three engine cover fasteners, grade-F. JIM
Old 07-08-2001, 11:36 AM
VenTTed's Avatar
Jim... can you post a pic of the wire you repaired? Would like to take a look in my car.
Old 07-08-2001, 12:24 PM
Jim TT's Avatar
Default Picture of repair...
<center><img src="http://pictureposter.audiworld.com/1319/aaabbb23645t.jpg"></center><p>The new ground wire is the fat yellow one, the original wire is green and brown.
Old 07-08-2001, 02:38 PM
Tron (///M)'s Avatar
Thanks for the info. Jim. So what does you engine cover say? I see some red at the edge in the pic
Old 07-09-2001, 06:00 AM
Jim TT's Avatar
The cover is off, that is just a warning label. #8)
lazy n00b
04-23-2007 11:10 AM
cas 01
1.8T Discussion
12-08-2006 01:37 PM
KingTT
11-20-2006 02:32 PM
ThirdEye
08-27-2002 02:22 AM
fireblade_rr
02-07-2002 07:03 PM
Quick Reply: Ground wire to boost control valve caused problem/problems
