  • MKI TT FAQ || Mk2 TT Forum || Audi TT Pricing Info
  • [Thread] [Post Followup] [Post Picture] [Search Forums] [TT (Mk1) Discussion]
    Is it possible for TB to slip due to lubricant getting on TB teeth?
    Posted by: Milpower on 2008-10-03 11:09:06
    Account #: 77906
    A little bit of jig-ga-lube "may" have gotten on the large metal gear wheel (not the teeth, but the arms).
    Liberally sprayed TB with belt dressing to offset possible lubricant (not oil or grease) on TB.
    Issue?
    2000 Lake Silver Metallic TTQC
    POWER: Modshack VTDA and MoFo w/4bar FPR (VAG-adjusted) | 034 Phenolic Spacer
    RUNNING GEAR: Koni FSD Struts and Shocks | MCPi DefCon 3 | 034 Tranny/Motor Mounts | Powerflex Dogbone
    ENGINE/TRANNY: Hose Technique Vacuum hose | SAIP Air Inlet Relo | Royal Purple 5W-40/Royal Purple Max-Gear 75W-90
    COSMO: Forge Shift Knob | Modshack TT Cupholder
    NUANCE: Rear Deck seal
    109K and coming back to life
    Thread:
    Login with existing account
    Create a new account
