  • MKI TT FAQ || Mk2 TT Forum || Audi TT Pricing Info
  • [Thread] [Post Followup] [Post Picture] [Search Forums] [TT (Mk1) Discussion]
    My status...
    Posted by: TTransport on 2008-09-03 08:19:53
    Account #: 80527
    In Reply to: How is your stroker beast coming along? you've got to take some video for us!! posted by iTTaliano on 2008-09-03 04:31:51
    The current solution is holding at the moment and is in the process of being fine tuned. It's got a ways to go, right now I'm working remotely with Jeff on tweaking the fuel and increasing the boost in small incremental stages. Once done with that baseline I will turn on my water meth, and tweak some more when I'm done and have it solid I'll do some video...
    My Build:
    New head from Bob at QEDPower, that is ported/perf valve job, cat springs, schrick cams.
    APR Intake that has been coated inside for high flow, and outside to reduce heat transfer, Phloenic Intake Gasket
    R32 Throttle Body
    Cold Air DV
    Delrio Piping
    Delrio Race FMIC
    GT 3071
    3bar Map sensor
    B5S4 MAF
    GIAC BT tune, with electronic boost controller (also manual boost controller for tuning purposes and spike control)
    Southbend K70287FE clutch
    VF Eng Mounts
    External fuel pump
    Forged 2.2L Eurospec block with girdle and deck cooling option (Def would not go that route again) Just say no to Eurospec!
    Setrab oil cooler and remote oil filter relo
    Water Meth
    MyFotki: Lots of Pics
    FAQ: Search-Before-Asking!
    2001 Audi TTQRoadster RavenBlack 2.2L->BT:
    Motor: 2.2 forged Crank/Rods/Pistons, Girdle & deck cooling, Custom QEDpower Head with Schrick cams and Cat springs
    Forced Induction: GT3071, DelRio Race Intercooler, DelRio BT Piping, Evo VFlo+ B5 S4 MAF, APR Bigport Intake ceramic coated, R32ThrottleBody, CoolingMist WaterMeth, larger injectors, fuelpump, etc
    DP-Exhaust: FastIntentions Custom 3”DP and Cat / test pipe section, BlackSheep Custom 3” cat back section with magnaflow resonator
    Suspension: VF Eng Mounts, KWV3+upratedfrontsprings, GroundControl C&C Plates, SpericalBushings ControlArm+Defcons+Poly, RearCamberBars, Uprated SwayBars
    Brakes: StoptechBBK 355 x 32 mm
    DriveLine: HaldexBlue + PeloquinRearLSD, SouthBendK70287FE
    Misc: Zeitronix EGT/WBAFR/Boost, Oil Temp/Pressure, Setrab oil cooler and oil filter relo, adjustable FPR/fuel pressure gauge
    Cosmetics: OSIR Fenders, SGI Carbon rear, 5PointHarness, race seat, custom front splitter, Black UFO, Black PC ValveCover, clear corners
    Pics from the 1st build
    Thread:
    Login with existing account
    Create a new account
