| [Thread] [Post Followup] [Post Picture] [Search Forums] [TT (Mk1) Discussion] |
a couple pieces to your testing criteria....
- you may want to test 3-bar FPR as not all are modshack tuned.. - obviously the 4 bar setup as well.. - adjustable FPR's will throw of your adaptation tables for the other two as it will be tuned in most cases to 3.7 or so bar... Not sure what the length is there, but that will also change your adaptation tables..i have been through this a lot.. Software can make a difference as well... While i doubt you will get any errors, those distances from the flow absolutely change your part throttle...most with hi-flow cats run in the 4.7 range on part throttle or a bit less....with an adjustabble FPR you can bring those numbers down to near zero around optimal values.... Just wanted to throw that out there.. _____________________________________ |
Terms of Use | Copyright © 1996-2008 by AudiWorld. All rights reserved. |
