for it to arrive before attempting the shocks and struts.
Audi is going to want the car in a few days for the cluster, so after that, I am going to put the car on ramps in my driveway and then remove the control arms (IF they will come out). Then, I'll send each unit and the associated hardware. Will package with bubble wrap and popcorn. I've got your address and thanks, in advance, for the help and good work.
2000 Lake Silver Metallic TTQC
POWER: Modshack VTDA and MoFo w/4bar FPR (VAG-adjusted) | 034 Phenolic Spacer
RUNNING GEAR: Koni FSD Struts and Shocks | MCPi DefCon 3 | 034 Tranny/Motor Mounts | Powerflex Dogbone
ENGINE/TRANNY: Hose Technique Vacuum hose | SAIP Air Inlet Relo | Royal Purple 5W-40/Royal Purple Max-Gear 75W-90
COSMO: Forge Shift Knob | Modshack TT Cupholder
NUANCE: Rear Deck seal
109K and coming back to life
