| [Thread] [Post Followup] [Post Picture] [Search Forums] [TT (Mk1) Discussion] |
Sounds a lot like sway bar bushings....
To lube correctly you really need to pull the brackets off but that's not a huge job... You can try spraying them with a silicone lube first to see if the noise goes away...Temporary fix though! Better yet, put a 19mm sway bar on with poly bushings! ......... |
Terms of Use | Copyright © 1996-2008 by AudiWorld. All rights reserved. |
