Does anyone know the prefered connection location for B+ after ignition.....
The defi gauges require B+ and B+ after ignition. The B+ I can get from the lighter, but not sure where a good B+ after ignition would be.
OK, thanks, I did find this on Jeff's site. The yellow is switched power.....
<center><img src="http://mk1tt.montebellopark.com/images/12vterminals.jpg"></center><p>
I guess I can tap into that, all wires will be fused.
B+ after ignition..... meaning switched 12 volts?
under the dash in the drivers footwell...
remove the lower cover
look for voltage distribution, you'll find a post or stud marked "75X" (the yellow label on the left, in your picture below)
it's "switched 12" with an "unloader" function
unloader means "not there" during engine cranking...
12v is present at 75X after the engine starts... until the ignition is switched off
(I used it for daytime running lights)
Vortec4800
01-19-2005 03:09 PM
lyonelll
01-02-2004 06:16 PM
budlight
16
06-06-2003 09:14 PM
ccagle8
09-11-2002 04:02 PM
