How-To (it's been a long time!): Rear Differential Oil Replacement...
A relative easy job, not on a maintenance interval. My fluid was darker that new, and there was minimal build up of metal (wear) flakes on the magnetic drain plug. Probably not a real need to do it, but not too expensive, so what the heck...
Open drain plug (17 mm Allen):
<img src="http://images29.fotki.com/v6/photos/4/435091/5517545/0217MMAllen-vi.jpg">
Drain fluid (it is "motor oil" and can be recycled with normal engine oil):
<img src="http://images30.fotki.com/v473/photos/4/435091/5517545/04Draining-vi.jpg">
Clean the drain plug of its flakes:
<img src="http://images22.fotki.com/v519/photos/4/435091/5517545/06MagneticPlug-vi.jpg">
Replace drain and open fill hole (17 mm Allen again):
<img src="http://images22.fotki.com/v519/photos/4/435091/5517545/08Fillplug17mmAllen-vi.jpg">
New oil (available at VW as well):
<img src="http://images29.fotki.com/v317/photos/4/435091/5517545/09OEMGearOil-vi.jpg">
Pump in a new liter of fluid, plug the hole, and you're good to go:
<img src="http://images30.fotki.com/v479/photos/4/435091/5517545/14FluidIncoming-vi.jpg"><ul><li><a href="http://public.fotki.com/mcphill/audi_stuff/engine_and_drivetrain/differential-oil-re/">A few more photos in the Fotki...</a></li></ul>
anyone done front bevel box/ differential?
Hi, I did mine a few days ago when I was doing the haldex oil change and fuel fitler. Nice write up.
Has anyone done the front differential bevel box? Isn't it a similar differential and need oil change too?
Yep. Same fotki. Change when you change the tranny fluid up front.
<ul><li><a href="http://public.fotki.com/mcphill/audi_stuff/engine_and_drivetrain/transmission_oil/">http://public.fotki.com/mcphill/audi_stuff/engine_and_drivetrain/transmission_oil/</a</li></ul>
The same, but different.
3.2 DSG bevel drive oil is separate from the transaxle oil. Other than having to refill separately, the procedure should be the same as the posting. Audi lists a special oil, but as far as I can tell MT90 should work.
I wouldn't chance anything other than OEM oil on the DSG... Too many odd things happening with
those IMO, and not a good place to "risk it"...
I would also bet the DSG does not use an Allen plug - even later TT's have a different shape (triple-square or Torx - I don't recall).
