Please help me with ALIGNMENT SPECS on lowered TT!! >>
Lowered substantially on coilovers and will be getting the rear adjustable lower control arms installed early next week.
Correct me if I am wrong... street driven but would like a somewhat aggressive set-up if there is such a thing..
-1.6 rear camber and 0 toe all around? What other numbers do i wanna make sure are around a certain amount? I can give them numbers and they will do exactly what i say (Al@CPT)...
Subframe etc? to make sure that is not messed up?
Thanks in advance.
Thanks in advance.
Here are the 'prefered' specs posted by others >>>
Front:
Camber: -0.8 deg
Cross Camber: 0
Caster: No Adjust
Toe: Toe IN (per side) - 0 to 1/32"
Total Toe: 0 to 1/16"
Steering Angle: 0
Rear:
Camber: -1.6 deg
Cross Camber: 0
Toe: Toe IN (per side) - 0 to 1/16"
Total Toe: 0 to 1/8"
Thrust Angle: 0
Camber: -0.8 deg
Cross Camber: 0
Caster: No Adjust
Steering Angle: 0
Rear:
Camber: -1.6 deg
Cross Camber: 0
Thrust Angle: 0
I run -1.5F 1.6R camber, I was told to go for as much camber as you can get up front
in order to achive better handling, and I haven't had any tire wear problems in a year on summers (thru winter!)
