Leak on TT Roadster
Old 12-01-2006, 05:02 AM
Junior Member
TThunderchild's Avatar
Default Leak on TT Roadster
Hello all. I have a small leak when it rains right at the point where the small window at the front of the door closes against the A pillar. Has anyone had this before and do you know how to stop it? I was thinking of using some Firestone rubber roofing material to close the seal tighter. That stuff has worked wonders for me on my truck. Thanks.
Old 12-01-2006, 06:06 AM
GeTT da NeTT's Avatar
Please post your solution. I have this too!
Old 12-01-2006, 07:25 AM
New Member
Felino Perdido-TT's Avatar
Default My roadster's top only leaks a little on the car wash...
When taking the high pressure cycle, I do get a little water on the passenger side, none on the driver side.
This makes me believe that this leak could be fixed some how, but I'm clueless as far as what to try...
The top structure looks flawless, and do are the seals. I get no airflow in while driving...
Are all these leaks progressive? Is there a best practice to prevent this from happing (or slow it down for that matter) ?
Be safe on the snow!
Old 12-01-2006, 09:30 AM
pTTs's Avatar
Default Same here...
Drivers side right same exact place..I end up stuffing a towel up there..usually only happens when its pouring out or car wash.
Old 12-01-2006, 01:00 PM
TTrampa's Avatar
Ditto --just some drops in the car wash
Old 12-01-2006, 02:00 PM
McTTR's Avatar
Default I took mine back to the dealer 3 times before they fixed it ....
First the replaced all the rubber. I'm not sure what the hell they did the second time and then the 3rd time they adjusted the tilt of the window. It worked.
The service manager admitted that they had overlooked the tilt fix. He said they found out that the windows had adjustment that would increase or decrease the tilt or lean into the car.
Whatever, it worked.
cctv
04-11-2011 10:01 AM
DaddyWarbucks
03-10-2006 01:37 PM
TTQuattro
11-13-2004 03:56 PM
cocteau
08-12-2001 12:20 PM
sharpy
10-11-2000 10:11 AM
Quick Reply: Leak on TT Roadster
