Frequently Asked Questions and Common Problems Thread Collection
#221
Re: Frequently Asked Questions and Common Problems Thread Collection
Hi all i have still got my mk1 180 coupe tt but when i turn left or hit a large bump in the road i get a loud bang from the off side front wheel can you help ?
#223
How do you put this thing up on jack stands?!
<ul><li><a href="https://forums.audiworld.com/tt/msgs/1557662.phtml">https://forums.audiworld.com/tt/msgs/1557662.phtml</a</li></ul>
#224
Plug for transmission case inspection hole part numbers:
<ul><li><a href="https://forums.audiworld.com/tt/msgs/1557909.phtml">https://forums.audiworld.com/tt/msgs/1557909.phtml</a</li></ul>
#225
broken switch in door latch-it can be fixed
<img src="http://mk1tt.montebellopark.com/images/newswitch8.jpg"><ul><li><a href="https://forums.audiworld.com/tt/msgs/1499451.phtml">Door Latch micro-switch replacement</a></li></ul>
#226
"My front end squeaks, what's the problem?"
It's the plastic sleeve that is supposed to be bonded to the swaybar. The sleeve breaks free, and then squeaks as it moves over the bar. There is a TSB on this, and there are two fixes.
$$$$ - put in a new OEM bar (new design is "sleeveless")
$ - Cut off plastic sleeves, and replace with polyurethane bushes, available from TTStuff (20 mm)<ul><li><a href="https://forums.audiworld.com/tt/msgs/1543699.phtml">https://forums.audiworld.com/tt/msgs/1543699.phtml</a</li></ul>
#227
How to change the License Plate light bulbs...
<ul><li><a href="http://public.fotki.com/mcphill/audi_stuff/lighting_systems/led_license_light_change/">http://public.fotki.com/mcphill/audi_stuff/lighting_systems/led_license_light_change/</a</li></ul>
#229
Plenum cover replacement...>>
I have to replace mine last weekend.
Tools:
- 13mm socket and ratchet
- diagnal cutters
- slotted screwdriver
- your fingers
Time allotted: 20 minutes.
<img src="http://images17.fotki.com/v349/photos/5/58883/1238797/plenumcoverremoval-vi.jpg">
Part #: 8N1-819-415-B-01C
This should fit all TTs.
Tools:
- diagnal cutters
- your fingers
