at a loss guys - what are my next steps? >>
i'm still getting the same code:
17579 - Angle Sensor 2 for Throttle Actuator (G188) Implausible Signal
it comes with the epc light and hard limp mode. the only fix is ignition off/on.
<img src="http://www.squarewave.com/army/andrew/ttStuff/tb_fix-007.jpg">
- is it possible this used throttle body i installed has the same issue as my original? do i try buying another one?
- could it be my boost machine? (this one is a stretch)
- the only thing left is the ecu. but why would it just have this one very specific problem? if my ecu was shot.. wouldn't there be other issues?
i'm looking for any ideas here. thanks.
old post below:<ul><li><a href="https://forums.audiworld.com/tt/msgs/1551055.phtml">https://forums.audiworld.com/tt/msgs/1551055.phtml</a</li></ul>
Idea........
Can you try to test the voltages, while wiggling the connectors? Both at the ECU and at the TB? Perhaps something is making intermittent contact. If not, try another TB. I know mine worked fine.....
Another idea perhaps...when I removed the black cover from mine...
I noticed one of the metal wipers was not marking the graphite wheel as much as the other ones, so I bent it slightly, to apply more pressure to insure complete contact. Just a thought.
See if these help, otherwise a new throttle body may be the best bet>>
http://www.audifans.com/pipermail/biturbos4/2004-November/003693.html
http://www.s4-mtm.com/images/Audi_S4_engine_english.pdf#search=%22Throttle%20Ac tuator%20(G188)%20Implausible%20Signal%22
(around page 40...happy reading!)
TwentyValveB5+S4
11-14-2006 02:04 PM
tybmw
10
11-04-2006 01:16 PM
tybmw
11-04-2006 12:20 PM
