Damnit. Throttle body issue still unresolved >>
After replacing the throttle body and pedal potentiometer last week I though I had fixed the car going into constant limp mode. But, under light acceleration last night, my friend returned...
17579 - Angle Sensor 2 for Throttle Actuator (G188) Implausible Signal
...and sent me into limp mode with an "EPC" light again. Now I have NO idea what it could be. This is a used throttle body - but what are the chances of it having the exact same problem as the original? I have even tried testing the voltages at the harness per the bentley's troubleshooting procedure. Everything was in spec. Please help!
<a href="https://forums.audiworld.com/tt/msgs/1545729.phtml" target="_blank">Post where I thought I had fixed it</a>
<img src="http://www.squarewave.com/army/andrew/ttStuff/tb_fix-007.jpg">
were all the codes cleared??? It might be possible that >>>
there is a error in the master table that re-initiated the problem....have you disconnected the battery and reset everything Andrew?
i didn't pull the battery - but i did reset the dtc's and >>
pull the ecu for a couple minutes to spray the connections with electrical cleaner.
should i still disconnect the batt? how long?
yeah - been there >>
<ul><li><a href="https://forums.audiworld.com/tt/msgs/1545729.phtml">https://forums.audiworld.com/tt/msgs/1545729.phtml</a</li></ul>
MaDBoX24
03-26-2019 03:19 PM
Sourdough Josh
03-07-2002 11:06 AM
