Blueflame exhaust install, part deux
Pic showing both tips
<img src="http://i6.photobucket.com/albums/y205/GLDE8R/blue1.jpg" alt="Image hosted by Photobucket.com">
Here's a close up of the tip
<img src="http://i6.photobucket.com/albums/y205/GLDE8R/blue3.jpg" alt="Image hosted by Photobucket.com">
the side view showing recessed tips
<img src="http://i6.photobucket.com/albums/y205/GLDE8R/blue4.jpg" alt="Image hosted by Photobucket.com">
Here's a look at what's going on underneath
<img src="http://i6.photobucket.com/albums/y205/GLDE8R/blue5.jpg" alt="Image hosted by Photobucket.com">
This is the missing tip not seen above (look again) it must be bolted on for adjustability
<img src="http://i6.photobucket.com/albums/y205/GLDE8R/losetip.jpg" alt="Image hosted by Photobucket.com">
..and you got to trim out some of the heat shield ..thanks, Schwing
<img src="http://i6.photobucket.com/albums/y205/GLDE8R/P5270071.jpg" alt="Image hosted by Photobucket.com">
a look at the other side
<img src="http://i6.photobucket.com/albums/y205/GLDE8R/blueside.jpg" alt="Image hosted by Photobucket.com">
the missing center bracket not missing here...had to add
<img src="http://i6.photobucket.com/albums/y205/GLDE8R/bluecenter.jpg" alt="Image hosted by Photobucket.com">
The kit came with everything needed but this,but will work without, too
<img src="http://i6.photobucket.com/albums/y205/GLDE8R/blue6.jpg" alt="Image hosted by Photobucket.com">
My car feels as strong as this (hyperbole)
<img src="http://i6.photobucket.com/albums/y205/GLDE8R/blue7.jpg" alt="Image hosted by Photobucket.com">
and this is what the tips look like after warm up.
<img src="http://i6.photobucket.com/albums/y205/GLDE8R/blue8.jpg" alt="Image hosted by Photobucket.com">
overall, a good exhaust with a nice rumble ala wah, wah, wah, wah, wah sound at idle and a little louder than stock at speed. The loose tip can be welded on later once the exhaust settles in and you got it good and aligned. Just make sure it's bolted on tight...and thanks to Nigel for the shirt, (baseball type (rounders) at that).
<img src="http://i6.photobucket.com/albums/y205/GLDE8R/MUSEUM045.jpg" alt="Image hosted by Photobucket.com">
