Well... I knew it wouldn't be long. Issues once more!!
Do you know what a TT that's only running on 3 cylinders sounds like? I do.
VAG-COM Version: Release 303.1
Control Module Part Number: 8N0 906 018 K
Component and/or Version: 1.8L R4/5VT G 0003
Software Coding: 06710
Work Shop Code: WSC 40334
Additional Info: TRUUT28N111027911 AUZ5Z0YD180003
8 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16688 - Cylinder 4 Misfire Detected
P0304 - 35-10 - - - Intermittent
16490 - Manifold / Barometric Pressure Sensor (G71) / (F96): Implausible Signal
P0106 - 35-10 - - - Intermittent
17925 - Main Relay (J271): Electrical Malfunction
P1517 - 35-10 - - - Intermittent
18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
P1650 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
16685 - Cylinder 1 Misfire Detected
P0301 - 35-00 - -
16687 - Cylinder 3 Misfire Detected
P0303 - 35-00 - -
8 Faults Found:
P0300 - 35-00 - -
P0301 - 35-00 - -
P0303 - 35-00 - -
How old is your battery?
Mine had the same fault code. My battery wasnt able to hold voltage when a draw was placed on it. The battery caused many, many little issues with my car when it went. Put a new battery, and everything was fixed.
Never seen a bad barometric pressure sensor???
Boy Chris, if it wasn't for bad luck you've have none. : ( Hope you get it figured)
Also, the wife and I are hooking up with the Illinois & Indiana group to TT East. They're coming down I-75 and we're meeting up at the Kentucky I-75/I-76? welcome center. 12:15 PM scheduled.
It's the TT Harley Davidson edition.
Ewww...it's jumping around too. Sorry to hear that. I would suggest you check the connector the dealership re-seated onm my car, but they never told me where it was. :^/
