Installation Procedure of R32 Aluminium Paddles!!!
This is it guys, a fully-documented procedure on how to swap the black pastic paddles that come standard on the 3.2 TT's for the aluminum ones seen on the VW Golf R32.
First, here are a few pictures of the new aluminium paddles to explain what needs to be done in order to take them apart:
1. Here are the paddles themselves, unpacked:
<img src="http://hitechgti.50megs.com/audi/paddles/paddles01.jpg">
2. Zoom-in on the right paddle:
<img src="http://hitechgti.50megs.com/audi/paddles/paddles02.jpg">
3. Here, the left arrow points at the Torx screw which also acts as a "pivot", and the right arrow points at the "lip" by which the paddles stay within short distance of the switch:
<img src="http://hitechgti.50megs.com/audi/paddles/paddles03.jpg">
4. The paddles ship with a protective layer of some sort, you can take it off now or leave it
on until the install is done:
<img src="http://hitechgti.50megs.com/audi/paddles/paddles04.jpg">
5. Use a Torx screwdriver to take the only screw all the way out:
<img src="http://hitechgti.50megs.com/audi/paddles/paddles05.jpg">
6. Hold the paddle steady as the spring will push it out further:
<img src="http://hitechgti.50megs.com/audi/paddles/paddles06.jpg">
7. Carefully pull the paddle back from the switch, keeping in mind not to lose the spring:
<img src="http://hitechgti.50megs.com/audi/paddles/paddles07.jpg">
8. Here is the spring fully released:
<img src="http://hitechgti.50megs.com/audi/paddles/paddles08.jpg">
9. Now you can remove the paddle, by pulling up then out to release the "tab" or "lip" from the switch:
<img src="http://hitechgti.50megs.com/audi/paddles/paddles09.jpg">
10. Here's the paddle fully separated from the switch:
<img src="http://hitechgti.50megs.com/audi/paddles/paddles10.jpg">
11. Now go to your car, turn the steering wheel 180° so that it is upside down, and unscrew the plastic paddles:
<img src="http://hitechgti.50megs.com/audi/paddles/paddles11.jpg">
12. Slowly push back the plastic paddles from the switches, keeping in mind that spring again:
<img src="http://hitechgti.50megs.com/audi/paddles/paddles12.jpg">
13. Here's a comparison pic between the aluminium and plastic paddles:
<img src="http://hitechgti.50megs.com/audi/paddles/paddles13.jpg">
14. Hold the aluminium paddle upside-down and place it behind the wheel:
<img src="http://hitechgti.50megs.com/audi/paddles/paddles14.jpg">
15. Slide the aluminium paddle into the appropriate switch:
<img src="http://hitechgti.50megs.com/audi/paddles/paddles15.jpg">
16. Screw the aluminium paddle in with the Torx screw, and adjust tightness for more or less "click":
<img src="http://hitechgti.50megs.com/audi/paddles/paddles16.jpg">
17. Repeat for other paddle, and Voilą!!
<img src="http://hitechgti.50megs.com/audi/paddles/paddles17.jpg">
18. View from the side:
<img src="http://hitechgti.50megs.com/audi/paddles/paddles18.jpg">
19. A couple of other pictures from another install:
<img src="http://hitechgti.50megs.com/audi/paddles/paddles19.jpg">
<img src="http://hitechgti.50megs.com/audi/paddles/paddles20.jpg">
The whole story of how these paddles finally came through, after the price jack from VW, can be found <a href="http://www.tt-forum.co.uk/ttforumbbs/YaBB.pl?board=WebTTForum;action=display;num=107522 5729">HERE</a> and a similar "how-to" post I made on the UK forum is <a href="http://www.tt-forum.co.uk/ttforumbbs/YaBB.pl?board=WebTTForum;action=display;num=107767 6725">HERE</a>.
I'm hoping to get mine installed soon, as they're waiting for me in Paris and I'm leaving on Thursday to pick them up - amongst other more important things of course.. ;-)
Enjoy!
-Marc
Enjoy!
-Marc
very nice write up, i glanced over, but it looks like you are ditching the
electronics on the new paddles, your just replacing the plastic with the new silver paddle which has been removed from the electronics?
That is correct, because:
1. it is just so much easier this way, and
2. the switch with all the electronics has a wire that turned out to be shorted than the TT's switch, so wire splicing would have to occur..
Eighth Member of AudiWorld. God-like, glorious and all-knowing.
Here's my original write-up on the subject...
<center><img src="http://images5.fotki.com/v55/photos/3/36284/641327/133_3326-vi.jpg"></center><p>
I was the Guinea Pig and my dealer did the installation. We've been discussing and refining the procedure ever since, and now we have an excellent documentation (thanks to Marc) on the installation procedure.
The bad news is that as the "pioneer", I had to spend about $100 for the installation. The good news is that I wasn't charged for the parts, as the shop that provided them thought that they might end up getting a fair amount of business from my idea. They almost did, but VW/Audi jacked up the price and that threw a wet blanket on things.
To view my writeup, follow the link:<ul><li><a href="https://forums.audiworld.com/tt/msgs/994180.phtml">R32 Aluminum Paddles Install</a></li></ul>
All hail Al!
Very cool. Any idea on the "off" graphic? Might just have a buddy of mine laser scan the parts and have 'em machined in Al. No doubt they'll be offered at some point soon by Forge or those Al nuts that have been slowly giving us all parts to turn the TT interior into the inside of a Calphalon pan - not that there's anything wrong with that.
TT 3.2 Silver/Blk Avus wheelset, BOSEII due in about a week. I think I felt a "kick" just now.
