Go Back   AudiWorld Forums > Community Discussion > Off-topic Discussion
Old 02-25-2004, 10:13 AM   #1
formerly dennisA4
Account #: 28728
Default How many lbs of baby-back ribs for 6 people?
3 of them are light eaters (women) and there will be sides and stuff of course. Also, I'm looking at this recipe for a rub. Any other last minute rub recipe suggestions before i go out and buy the ingredients?
2 1/2 tbs dark brown sugar
2 tbs paprika
2 tbs mustard powder
2 tsp onion powder
2 tsp garlic powder
1 1/2 tsp dried basil
1 tsp ground bay leaves
3/4 tsp ground coriander seed
3/4 tsp ground savory
3/4 tsp dried thyme
3/4 tsp ground black pepper
3/4 tsp ground white pepper
1/8 tsp ground cumin
salt to taste
formerly dennisA4 is offline   Reply With Quote
Old 02-25-2004, 10:15 AM   #2
whodkne
Member
Account #: 18343
Default 2-3 Racks should do it... about half rack per person figure..
whodkne is offline   Reply With Quote
Old 02-25-2004, 10:16 AM   #3
vr6corradoslc
Account #: 25412
Default Tabasco Chipotle
just in case you don't get enough smoke flavor.
vr6corradoslc is offline   Reply With Quote
Old 02-25-2004, 10:16 AM   #4
traffic626
Account #: 23164
Default I like racks.
:-D
I'd get 3. Leftover ribs are good.
traffic626 is offline   Reply With Quote
Old 02-25-2004, 11:04 AM   #5
Dave M
Member
Account #: 2200
Default If the ribs are "enhanced"
i.e. injected with sodium and other things to make them tender, then go very easy on the salt! If they are pre-packaged look for warning terms on the package like "always tender" "enhanced" "injected" etc and read the fine print. If they are not pre-packaged ask the butcher if they are enhanced or not.
You can lightly coat the ribs with some mustard, Jack Daniels Honey Mustard works well, before putting the rub on them (and elimiate the mustard from your rub). You should let them marinate for a while (4 hours or so) after applying the rub.
Dave M is offline   Reply With Quote
Old 02-25-2004, 11:53 AM   #6
formerly dennisA4
Account #: 28728
Default Thanks for the tips!
Was gonna let them marinate wrapped in plastic wrap for about 36hrs.
Old 02-25-2004, 12:56 PM   #7
Dave M
Member
Account #: 2200
Default No problem (more)
36 hours might have been a little long - with the salt they might start to cure. Marinating them overnight should be OK, but I would not go longer than this. Ribs are fairly thin and it does not take too much time for the rub to soak in.
BTW, putting the mustard on the ribs helps create a nice crust and it holds the rub on, too. That might not be an issue if you are not smoking them, or would rather not have a light crust on them.
Also, smoking "enhanced" ribs will result in a ham-like taste that is not very desireable. If you are grilling them it might not be as big of an issue, but you still need to watch any salt additions.
One last tip, remove the thin membrane on the bottom side of the ribs. You can use a butter knife to peel it away from the bone on one end, then grab the membrane with a paper towel and peel it right off the rest of the rib. This will make the ribs much easier to eat since you won't have to deal with that tough membrane, and it will also allow the rub to penetrate that side of the rib.
Old 02-25-2004, 01:04 PM   #8
formerly dennisA4
Account #: 28728
Default ok cool. muchos grassyass. :)
10, 12, 15, baby, babyback, back, buy, lbs, od, people, person, pounds, rack, ribs, sides
HTML code is Off
Forum Jump
