Go Back   AudiWorld Forums > Community Discussion > Off-topic Discussion
Old 11-22-2002, 11:24 AM   #1
akediord
Senior Member
Account #: 29942
Default Why do tires scallop/cup on inside or outside edge? Alignment or balance. Which one's the culprit?
Both of my fronts are cupping on the inside edge. Independent shop did an alignment, I wasn't happy and they gave me a refund. My ****ty-*** Nissan dealer can't do alignments on 18s so they are useless.
akediord is offline   Reply With Quote
Old 11-22-2002, 11:27 AM   #2
thermonuclear
Account #: 27673
Default alignment
too much camber if i remember correctly? toe, if not.
thermonuclear is offline   Reply With Quote
Old 11-22-2002, 11:38 AM   #3
S4iowa
AudiWorld Expert
Account #: 36175
Default This might help you.
My guess is they are probably scalloped and it is due to to much toe-out. toe-in would wear on the outside edge.<ul><li><a href="http://www.metropark.com/safewaytire/tireware.html">http://www.metropark.com/safewaytire/tireware.html</a</li></ul>
Current:
2004 S4
No Warranty:
66K Fuel filter $45
67K Motor mount $200
67K Coil pack(s) $40*2
67K Window regulator $100
71K Battery $135
2003 TT 1.8T
No Warranty:
50K Hazard Switch $50
Past:
1998 A4 1.8TQMS
B6/7 S4 Hawk Pad part number update!
Should no longer need to do the below anymore:
How to modify C5 A6 Hawk pads for use in the B6/B7 S4 or B7 A4
S4iowa is offline   Reply With Quote
Old 11-22-2002, 11:39 AM   #4
Evilclown
AudiWorld Uber User
Account #: 13879
Default Why are you getting an alignment already?
Evilclown is offline   Reply With Quote
Old 11-22-2002, 11:42 AM   #5
Silver Streakin'
Member
Account #: 10901
Default if it's feathered across the tire then, inside = toe out, outside = toe in. more tire info. -->
If it's just the edge then, inside = too much neg. camber and outside = pos. camber, which is rare and I'm not sure that you could with an Audi. It would have to be way out of spec.
go to the alignment section:<ul><li><a href="http://www.discounttiredirect.com/right_help.html">http://www.discounttiredirect.com/right_help.html</a</li></ul>
-Jeff
2001.5 A4 1.8TQMSCC with APR SIII, EVO FMIC, Stoptech-less, STaSIS Tracksports 600F/750R
ACNA MidOhio video
Montreal race school and PDA Pocono video
Silver Streakin' is offline   Reply With Quote
Old 11-22-2002, 11:47 AM   #6
Andy_FL
Account #: 12690
Default Could also be bad/worn tie rod ends.
Andy_FL is offline   Reply With Quote
Old 11-22-2002, 11:50 AM   #7
Evilclown
AudiWorld Uber User
Account #: 13879
Default On a brand new Z?
Old 11-22-2002, 12:03 PM   #8
akediord
Senior Member
Account #: 29942
Default Excellent. Thanks!
Old 11-22-2002, 12:04 PM   #9
akediord
Senior Member
Account #: 29942
Default Thanks!
Old 11-22-2002, 12:05 PM   #10
akediord
Senior Member
Account #: 29942
Default Because it was pulling to the right just a bit. Seems to afflict a lot of Zs...
and I was trying to do something about it.
alignment, cup, cupping, edge, inside, makes, oustide, race, rare, rear, scallop, scalloped, scalloping, scallops, tire, tires
HTML code is Off
Forum Jump
