Go Back   AudiWorld Forums » Technical Discussion » Wheels & Tires Discussion
Sponsored by: Tire Rack
Old 09-30-2003, 06:03 PM   #1
fenixxx
Member
Default Need a definitive answer, search didn't help... (m)
Would a 18x8 with a 40mm offset with 225/40ZR18 tires fit on my 2002 A4Q non-sport? I am thinking about lowering it after I get the tires, about 1.5" or so, would I be able to do that too? TIA
fenixxx is offline   Reply With Quote
Old 09-30-2003, 07:09 PM   #2
Gorobei
Elder Member
Default With that offset, clearing the fender is less of a concern than clearing the brakes/suspension.
Could be close. Can't tell you for sure, though. Which wheels, exactly? Those are odd specs for an Audi fitment.
Phantom Black / S-Line / Heated Seats / Tech / Nav+ / Bluetooth / XM / Carbon Fiber Trim
Stasis Streetsport / APR 91,93,100 / APR Exhaust / H&R Adjustable Rear Sway / AWE Pedals / Bridgestone RE750
Clear Corner / Painted Reflectors / VAG-COM mods / V1 Hardwire / Debadged / 3M 20% Tint
My B7 clear corner writeup:
http://forums.audiworld.com/a4b7/msgs/88996.phtml
Gorobei is offline   Reply With Quote
Old 09-30-2003, 08:37 PM   #3
fenixxx
Member
Default Not sure of the name, a friend of a friend of a friend is selling his, sorry I don't know much else
Old 09-30-2003, 09:31 PM   #4
MikekiM@PureMS
Audiworld Premium Sponsor
Default Wrong tire size..
B6 A4's use a 235/40/18 tire size. It's not optimal.
The wheel offset is a bit on the high side, but should fit.
www.purems.com
866-397-5487 | San Diego, CA | mike@purems.com | Specials on Twitter!
MikekiM@PureMS is offline   Reply With Quote
Old 09-30-2003, 10:43 PM   #5
Onie
Default Need 5mm spacer
2013 S4 Estoril Blue
2007 A3 Silver
2005 A6 Oyster Gray
2003 A4 Crystal Blue
Garage: 2001 TT 1964 Beetle 1965 Split Window Bus
Onie is offline   Reply With Quote
Old 10-01-2003, 04:37 AM   #6
Gary@Tirerack.com
Audiworld Basic Sponsor
Default Exactly, check suspension clearance carefully, and 235/40R18 is perferred for load capacity.
Borderline fitment.
Gary@Tirerack.com
Tire and Wheel Forum Moderator
The Tire Rack, Sales Rep
Reference 'Gary/Audiworld' as 'previous contact' when you order at our site.
The TireRack Tech Center
1-877-522-8473 ext 4386
Gary@Tirerack.com is offline   Reply With Quote
Old 10-01-2003, 11:05 AM   #7
cyberpmg
2004 Audi A4
Send a message via AIM to cyberpmg
Default The wheel should be fine with a 5mm spacer. Tire size should be 235/40R18
I have 18x8 Borbet Type R wheels with a 35mm offset. I also have 235/40R18 tires. The extra width is needed for several factors: load capacity, maintaining overall tire diameter, and rim protection. A 235/40R18 is the only size that closely maintains the overall wheel diameter and is therefore a true +2 upgrade from the OEM 16" wheels. This helps to ensure you don't throw off the spedo and tach.
The 40mm offset sounds dangerously close to the suspension hardware and subject to possible road damage. The 35mm offset on mine clears the suspension and doesn't interfere with the fender. Take a look at the pictures in my picture poster, and you'll get a good idea of the setup.
BTW, I've also lowered my A4 1.6" up front and 1.5" in the rear. Wheel setup is still good.
cyberpmg is offline   Reply With Quote
HTML code is Off
