| Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
Sponsored by: Tire Rack |
#1 | ||
#2 |
Member
Most Common Tire Wear Problems (typically speaking)
Wear On Both Edges: UNDER INFLATION The worst enemy a tire can have is too little inflation pressure. Underinflation reduces treadlife through increased tread wear on the outside edges (or shoulders) of the tire. It also generates excessive heat that reduces tire durability. Finally, it reduces fuel economy through increased rolling resistance (soft tires make your vehicle work harder). Check your tires regularly for proper inflation. Wear In Center: OVER INFLATION When a tire is over inflated, the center of the tread bears most of the load and wears out faster than the outside edges. Uneven wear reduces the useful life of a tire. Check your tires regularly for proper inflation. Cups or Dips in the tread: WORN PARTS Cupping (also called dipping or scalloping) is most common on front tires, though rear tires can cup as well. It may be a sign that wheels are out of balance or that suspension or steering system parts are worn out. Wear on one side or sawtooth edges: MISALIGNMENT Abnormal tire wear may also be due to misalignment or mechanical problems. Do the edges of the tread take on a sawtooth or feathered appearance? Erratic scrubbing against the road causes this treadwear. The solution is toe-in or toe-out alignment correction.
Eddie 2107- ![]() FORMER AudiWorld Wheel/Tire Forum Moderator |
| Tags |
| scalloping, tire |
