Go Back   AudiWorld Forums » Technical Discussion » Wheels & Tires Discussion
Sponsored by: Tire Rack
Old 06-14-2002, 08:05 PM   #1
squrlathon
Junior Member
Default 18" Superleggeras....what are the chances they will rub ??
on my '94 90 Quattro ? Currently I've got stock shocks and H&R springs, so I'm lowered about 1". I will get bilstein or koni sport shocks when i get the new wheels. How strong are the Superleggeras REALLY ? Should I be considering a heavier rim if I go to 18", or even 17" ? I'm located in Toronto. Some of our roads are not great...
I'm considering the new Dunlop SP FM901's. Any opinions on these? They are on sale right now --my other choice for almost twice the money is the S03 Pole Positions...
1994 Audi 90 Quattro (Audi Green)
Ported/Polished Heads
Ported Intake/Exhaust Manifolds
Ported/Polished Throttle Body
Eurospec 268 CAMs
K&N Cone Intake
S2 inlet hose
Custom 2.5" cat-back exhaust, dynamax cats, stainless Magnaflow with DTM's
Brembo rotors, Wilwood dynalite II calipers with goodridge teflon lines and Hawk pads-- courtesy MikTip
H&R Springs
Mance Solid Strut Mounts
Mance Snub Mount
Momo Champion steering wheel
Billzcat Short Shifter
Momo RaceAir shift ****/Momo Boot
Momo pedals with yellow accents
Tachoringe aluminum gage cluster trim
Light Tint
Clear corners
Stereo:
Head unit -- Alpine CDA 7998
Amp -- Phoenix Gold 600.1
Speakers -- AVI in custom pods
Subwoofer -- AVI 12" custom sealed box
Stock 10-spoke Audi rims with Michelin Arctic-Alpine snow tires.
Coming soon:
Sparco Milano seats (beige alcantra)
Bilstein shocks, 2Bennett delrin bushings
RS2 ellipsoid headlights, HID
Modified MAF (Mance)
Allroad Transmission mounts (modified)
Euro steering column cover
squrlathon is offline   Reply With Quote
Old 06-15-2002, 08:24 AM   #2
Kevin
Default here you go
OZ wheels are quality made wheels. I heard that hammann wheels for bmw were made by them too. So, it should be very strong.
If you need these wheels/suspensions, tirerack.com & globalautoshop.com have the best prices. Hope this helps
Kevin is offline   Reply With Quote
Old 06-15-2002, 09:36 AM   #3
Eddie@Tirerack
Member
Default Re: 18" chances they will rub ??
well, the largest size on the 90-series is 17", mostly die to clearance restrictions, so for ANY 18" wheel, I would not recommend, esp with the offset for the OZs being 32 mm- VERY agressive.
You should plan on them not working..
Call me if I can help!
Eddie 2107-
FORMER AudiWorld Wheel/Tire Forum Moderator
Eddie@Tirerack is offline   Reply With Quote
Old 06-17-2002, 11:25 AM   #4
George Burdell
Senior Member
Default SL strength
I have a set of 18's on my 2001 S4 Avant. I've had the misfortune to hit some poorly marked road construction. I would say the wheels are very strong. I've flatted the lips on two wheels on some pretty big stuff. One was about a 1" lip from asphalt to concrete at about 60mph in the center of a large dip. The second was a large pothole about 3" deep and 6" wide. The lip (which is actually about 3mm thick) bent, but nothing else. The wheel is otherwise round and true. Beads were unaffected.
For this kind of weight, you can expect big stuff to bend them.
As for rubbing, I can't say for sure, but in going from a 7.5" wheel with an ET45 to an 8" wheel of ET32, the tire is about 1-1.5cm closer to the fender.
'05 Subaru Impreza WRX STi - Crystal Grey
George Burdell is offline   Reply With Quote
HTML code is Off
