Go Back   AudiWorld Forums » Technical Discussion » Wheels & Tires Discussion
Sponsored by: Tire Rack
Old 11-05-2001, 05:55 AM   #1
Gold A4
Default Attn Eddie
I posted this over the weekend but was hoping you would see it. Can you also make specific recommendations for both the wheels and tires? I like the look of 5 spokes and want better handling but not at the total expense of ride comfort. I don't drive that aggressively that often. Following is the post:
I have a 2001.5 A4 with the stock suspension and 15" OEM wheels with Eagle LS 205/60/15 tires. I will be placing Blizzaks on these rims for the winter. Next spring I want to upgrade wheels and tires. Everyone tells me to upgrade the suspension but because of where I live, nearly a dirt road and lots of snow, I need the ground clearance. Thus, I will not be lowering the car and will live with the stock suspension. With that in mind, can I go to 17" wheels and slightly larger tires then is recommended to decrease the wheel gap? I understand that the speedometer and all will be off but I can live with that if not to bad. Also, what would be better looking, 16s or 17s with the larger tires? If this is not a good idea, then what would be better, 16s or 17s with the correctly sized tire? Thanks all for taking the time to read this and give your opinions.
Gold A4 is offline   Reply With Quote
Old 11-06-2001, 07:39 AM   #2
Eddie@Tirerack
Member
Default Re: Attn Eddie
Thanks for the note. The wheel styling is your preference, not mine, so I leave that up to you to take a look at our site.
On tires, if you go up to 16" you will be able to go a bit wider, up to a 225/50R16 for a boost in handling. As for the tires, again, I will want to speak with you to get more info about what you need the tire to do fo r you- the tires are the easy part.
Take a look at the wheels & call me once you pick out your best 2 or so, and I can then put it all together for you!
Thanks!
Eddie
Eddie 2107-
FORMER AudiWorld Wheel/Tire Forum Moderator
Eddie@Tirerack is offline   Reply With Quote
HTML code is Off
