Question about the middle number in a tire size (e.g., 50 v. 55)
Old 05-17-1999, 08:13 PM
Brian
Guest
Posts: n/a
Default Question about the middle number in a tire size (e.g., 50 v. 55)
In a tire size such as 225/50/16, the middle number is related to the "tallness" of the tire, no? So if I were to put 55s instead of 50s, the car would sit a little higher off the ground?<p>And if this is correct, what other effects does messing with this parameter effect? Speedometer accuracy would seem to be an obvious one. <p>I'm just wondering if I should opt for 55s when I replace my stock Contis with Dunlop 4000s.
Old 05-17-1999, 08:48 PM
LCP
Guest
Posts: n/a
Default Middle number is aspect ratio (height %)...
205/55-16 means that the height of the sidewall of the tire is 55% of the width of the tire, or 55% of 205mm. Take this number times 2 and add the wheel size and you'll get the total wheel and tire height. This also means that 225/50-16 yields almost exactly the same height.
Old 05-18-1999, 03:29 AM
Brian
Guest
Posts: n/a
Default Re: Middle number is aspect ratio (height %)...
Thanks!<p>Okay then - this means (using your examples) that a 225/55-16 would be almost an inch (22mm = .87") taller overall? Is that correct?<p>225 x 55 x 2 = 247.5mm<br>205 x 55 x 2 = 225.5mm<br>----------------------<br> = 22mm or .87"<p>That's a significant height change! <p>My real question then is, why don't people seem to use this factor when attempting to raise/lower their cars (I mean just change height -- not performance issues -- pure cosmetics)? It just seems like one could get even a small adjustment to height by using a small tire size change. For example, if I wanted to raise my car 10mm (I just put on H&R springs and Bilsteins), why couldn't I just replace my stock 205/55-16 tires with 215/55-16s? That would give a height difference of 11mm, if I'm calculating and understanding this concept correctly.<p>-Brian
Old 05-18-1999, 06:13 AM
Dave W
Guest
Posts: n/a
Default Shouldn't change the overall diameter
The reason why people don't, or shouldn't use this method to change the ride height is because you are changing the overall diameter of the wheel/tire. If you add an inch to the outside diameter, the speedometer would be off. To keep the speedo correct, the overall diameter of the wheel/tire needs to remain constant. This is where the idea of + and - sizing comes from. You can "plus 1" size a 16" wheel by going to a 17" wheel, but the tire will have a shorter profile to keep the overall diameter the same.<p>Hope this helps<br>dave<p>17" wheels
Old 05-18-1999, 11:04 AM
LCP
Guest
Posts: n/a
Also don't forget the car only gets 1/2 as higher/lower as the wheel/tire does
Old 05-18-1999, 04:16 PM
Brian
Guest
Posts: n/a
Thanks everyone for the responses. Very helpful and interesting stuff.
DaddyWarbucks
15
03-27-2006 07:13 PM
trojansruleucla
12-16-2002 08:07 PM
lskolnick(original)
11
12-11-2002 11:28 AM
Ty_96Q
10-18-2001 07:14 AM
Michael Pagano
12-07-1999 01:50 PM
Quick Reply: Question about the middle number in a tire size (e.g., 50 v. 55)
