| Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
Sponsored by: Tire Rack |
#1 | ||
Guest
Posts: n/a
#2 |
Guest
Posts: n/a
The 205/55/16 diameter is 24.83".
The 225/50/16 diameter is 24.88". If you are using the same width rim for both applications, the 225 will provide a more performance orientated ride in that you would probably run slightly higher pressures in the 225 w. a lower profile height, which should translate into a more performance orientated ride, ie: slightly stiffer. IMO if I had a rim width of 7" or more, I'd definitely opt for the 225 width if it clears everything and on an Audi it does. JMO, Gary. |
#3 |
Guest
Posts: n/a
If the diameter is virtually the same, how can then the 225/50/16s have a lower profile height than the 205/55/16s?
#4 |
Guest
Posts: n/a
The profile of the tire is the ratio of sidewall height to tire width. Therefore to use a wider tire it must have a lower profile if diameter is to remain essentially constant. In the case of the tires you mention, the 205 has a 112.75mm sidewall height (205 x 0.55). The 225 has a 112.5 sidewall height. For more info, check any of the tire tech pages at TireRack, or most of the tire manufacturers' pages.
Regarding the performance question, the ride quality should be similar with either tire if the tire pressures are the same. A higher inflation pressure will give a stiffer ride. It has nothing to do directly with the volume of air. Hope this helps. Regards, Dean W. |
