Go Back   AudiWorld Forums » Technical Discussion » Wheels & Tires Discussion
Sponsored by: Tire Rack
Old 11-14-1998, 04:51 PM   #1
Roy M
Guest
Posts: n/a
Default What air pressure are you using with winter tires (195/65R15)??
The A4 manual tell you to run 3 psi more on winter tires. I am using 38 psi with my stock tires. So for winter I should be using 38 + 3 = 41 psi. The side walls of the Bridgestone Blizzak states max inflation pressure is 35 psi.
What are most of you using??
TIA
Roy M 2.8q Tip (Using 35 psi in my new Blizzak's)
Old 11-14-1998, 07:30 PM   #2
Steve Mac
Guest
Posts: n/a
Default 36 psi in my Michelins (same size)
Old 11-14-1998, 10:22 PM   #3
Rau Calvo
Guest
Posts: n/a
Default Re: What air pressure are you using with winter tires (195/65R15)??
I intend to follow the recommendations on the gas filler lid, which I believe say 38 psi for a 195/65X15
98.5 Avant
Old 11-15-1998, 07:07 PM   #4
Brent
Guest
Posts: n/a
Default Seems way too high
I'm not an expert, but 41 psi in a vehicle as light as the A4 is damn high. I would like someone to tell me just why you couldn't safely run at 30 psi and not cause any undo damage to your car. I dare anyone to say you will get better performance out of a winter tire at 40 psi vs. 30 psi (on an A4).
Old 11-16-1998, 06:50 AM   #5
Steve Mac
Guest
Posts: n/a
Default Re: Seems way too high
41 psi does seem too high, and IS too high for a tire rated at 35 psi max. But the A4 is not a particularly light car (3200-3500 lbs, depending on equipment) and the recommendations for tire pressure are based on that weight, as well as other factors, I'm sure. Of course, I'm coming from a Jetta, so my perspective may be somewhat skewed!
The high inflation pressure comes into play when the car is operated with high loads (5-up with a full load of luggage) where the proper inflation pressure is 42/42 rather than 32/32 and I suspect that tires with a load rating of 91 (as are the OEM tires) are able to support the pressure and the weight.
As always, YMMV
Steve
195, 19565r15, 65r15, air, audi, blizzak, bridgestone, inflation, p19565r15, pressure, proper, psi, q5, recommendations, tire, tires, winter
HTML code is Off
