Go Back   AudiWorld Forums » Technical Discussion » Wheels & Tires Discussion
Sponsored by: Tire Rack
Old 11-03-1998, 10:52 AM   #1
Chris H.
Guest
Posts: n/a
Default Wrenching question
Can anyone tell me the "correct" number of pounds to set on a torque wrench for tightening the lug nuts on Audi wheels? THANKS!
--Chris H.
98 Avant QMS 2.8
Old 11-03-1998, 11:00 AM   #2
CraigB
Guest
Posts: n/a
Default 90 ft/lbs...
Be sure and check them, after the wheels have been removed/replaced by ANY shop. I had brake pads installed the other day and the Audi dealer must've put at least 200 ft/lbs on 'em, when they re-installed the wheels. HTH.
CraigB
Old 11-03-1998, 12:34 PM   #3
John
Guest
Posts: n/a
Default Re: Torque
Craig (or anyone):
Do you need to jack or raise a car simply to loosen or adjust the torque on the bolts? Just wondering as I have a rotation service coming up at 7500 miles.
Old 11-03-1998, 12:58 PM   #4
Jim Simone
Guest
Posts: n/a
Default Torque 'em on the ground
You have to torque the wheels on the ground since it's otherwise kinda hard to keep them from turning. :-)
Just loosen the bolts a little and re-tighten with a torque wrench in sequence, following the recommended "star" pattern.
(Check out this link to the Tire Rack tech info: http://www.tirerack.com/wheels/tech/torque.htm if you're unsure what I mean.)
Or, you could just wait until your next service and ask them how they properly torque the wheels.
HTH,
Jim
Old 11-03-1998, 01:03 PM   #5
david
Guest
Posts: n/a
Default it is only 10 lbs but...
I just checked my owners manual this weekend and I thought it read 80 lbs. I do not think 80 vs 90 matters.
Old 11-03-1998, 01:18 PM   #6
CraigB
Guest
Posts: n/a
Default Actually, I read somewhere...
...80-90 ft/lbs for 14mm bolts (since the torque is based on the bolt/nut and not the type of wheels). It was a list of different size lug bolts/nuts and their appropriate torque range; may have been on Tirerack or Discount Tire website. If I find it, I'll post the link.
CraigB
Old 11-03-1998, 01:24 PM   #7
CraigB
Guest
Posts: n/a
Default Here's the torque info link...
My mistake, 14mm uses 85-90 ft/lbs. Of course, this link also says to go by the manufacturer's recommended torque, which is probably 80 (I was just too lazy to look it up; I found 90 in the archives). HTH.
CraigB
Old 11-04-1998, 07:18 AM   #8
Chris H.
Guest
Posts: n/a
Default THANKS to all those who provided advice!
nt
Old 11-04-1998, 08:12 PM   #9
DJW
Guest
Posts: n/a
Default Re: 80 vs. 90 ft-lbs -- my manual DOES say 90...
HTML code is Off
