Go Back   AudiWorld Forums > Audi Models > Audi A4 > A4 (B5 Platform) Discussion
Old 03-03-2009, 07:13 PM   #1
hrlcustoms1979
Account #: 159130
Default My Audi is in "limp mode" and won't shift into 5th gear.
I have a 1999 Audi A4 1.8T Quattro. It all started with the car not shifting into 5th gear and the PRND being all lit up(what I have heard them call limp mode). At the same time my ABS light was on and my reverse lights would stay on in drive.
We first started by replacing the Multi-function Switch. That fixed the reverse light problem, but nothing else. Then, we decided to have our ABS Module rebuilt in hopes that it would fix all other problems. When we put the rebuilt one back in the ABS starting working again and the light went out.
Now we are out of ideas as to why the car is still in "limp mode" and won't shift into 5th gear. So we took the car to the Audi dealer and basically they said that the Multi-function Switch we had replaced must be faulty and that we need to replace it again. Does anyone have any ideas where we can go from here. Our mechanic (who is also a friend) is pretty darn sure it's not the Multi-function Switch. Any help would be greatly appreciated!
hrlcustoms1979 is offline   Reply With Quote
Old 03-03-2009, 07:21 PM   #2
Nate (ETKA+Scumbag)
Keeper of the Cash
Account #: 81303
Nate (ETKA+Scumbag)'s Avatar
Default Total failure of people going on here. You NEED to scan the TCU to see WHY it's failing
If it's setting limp mode, it had a damn good reason.
VAG-COM can tell you that reason.
"There might be intelligent beings created by God in outer space even if there are none here on Earth."
Nate (ETKA+Scumbag) is offline   Reply With Quote
Old 03-03-2009, 08:25 PM   #3
Birdman86
Account #: 122091
Default thats because "Top Gear" is soooo much better... ;) sorry. no constructive advice here. 5sp FTW
"70K for an RS4? no biggie" Now only if I could get the bank to think so.......
Comrade Obama will save us all!! :/
Birdman86 is offline   Reply With Quote
Old 03-03-2009, 08:30 PM   #4
freakness
Member
Account #: 13451
Default WHY DO YOU HATE AMERICA ?
I think that's what Mandeep would say . . .
* shrugs *
Currently driving a 1987 Toyota MR2 - Awesome ! Totally AWESOME !
Segata Sanshiro > Chuck Norris
freakness is offline   Reply With Quote
Old 03-04-2009, 02:55 AM   #5
4Driver4
Tech Guru
Account #: 43812
4Driver4's Avatar
Default What codes are you seeing? Can't help without information.
4Driver4
Growing old is mandatory; growing up is optional.
1980 VW Scirocco (mid-life crisis car)
1983 Mazda RX-7 (revolutionary sports car)
2003 Mini Cooper S (just because)
1995 Mazda Miata, Superdupercharged(anti-Audi)
1999 Mazda Miata SSB (track beotch, no plate)
2003 GMC Yukon Denali XL (the anti-earth)
2004 Dodge Dakota (hey, at least it's stick and 4x4)
Old 03-04-2009, 09:21 AM   #6
Nutch
Account #: 102217
Default You'll need a scan tool that reads Audi proprietary codes, not just OBD-II. But here's one quick...
check:
Disconnect wiring harness connector to multi-function switch at left front side of tranny and thouroughly clean contacts with electronics cleaner. Closely examine contacts and ensure they are not corroded.
Beyond that, you'll need a VAG-COM or equivalent to check ATF level, read TCM codes, or run tranny diagnostics.
1999.5 Audi A4 1.8TQ Tiptronic
2007 VW Jetta 2.5 Wolfsburg Edition
"Either do it yourself or always wonder."
"Don't mod it until it wears out or breaks."
"Don't take it easy because you'll never catch up."
Nutch is offline   Reply With Quote
Old 03-17-2009, 12:11 PM   #7
ThunderAlley
Banned
Account #: 102119
limp....lol
ThunderAlley is offline   Reply With Quote
1999, 2002, 2004, a4, a6, allroad, audi, b5, engine, limp, mode, multifunction, quatro, quattro, shift, switch
Forum Jump
