Go Back   AudiWorld Forums > Audi Models > Audi A4 > A4 (B5 Platform) Discussion
Old 02-12-2009, 07:20 AM   #1
aluminumpork
Account #: 95023
Default Removing clutch fan without special tool...
So I've pulled the plastic fan itself by removing the four little allen bolts and now I'm trying to figure out how I'm going remove the reverse threaded nut to actually pull the fan clutch off. I've looked around at some of the timing belt walk-throughs and they always say "I was able to figure it out by improvising". One said they used a little allen wrench to jam into one of the pulley's holes. I wasn't able to get anything to hold it as tightly as necessary.
Thanks.
aluminumpork is offline   Reply With Quote
Old 02-12-2009, 07:25 AM   #2
4Rings::G2 boosted::
Banned
Account #: 29132
Default allen key in the hole works great each time I had to do it
4Rings::G2 boosted:: is offline   Reply With Quote
Old 02-12-2009, 07:39 AM   #3
aluminumpork
Account #: 95023
Default Do you stick the short end of the allen in and rotate the pulley until it hits a metal rib behind it
or the long end and then wedge it against something exterior to the pulley?
Old 02-12-2009, 07:39 AM   #4
Carson (K03x2)
Account #: 51556
Default 2nd.
Carson
'99 A4 1.8TQMS T28 Santorin Blue
'06 A3 2.0T DSG Brilliant Black - the wifemobile
Audi Parts Consultant
Carson (K03x2) is offline   Reply With Quote
Old 02-12-2009, 07:47 AM   #5
Banned
Account #: 29132
Default long end until it wedges behind the pulley
Old 02-12-2009, 08:15 AM   #6
tehaudi
Account #: 51968
Default I had to order a spanner wrench($12 shipped), and it was not reverse threaded. Broke stuff trying to
use other things. Ordered from www.slgtools.com
Current
1995 Audi S6 Avant: MTM 1+, Hyperco Euro Reps/Konis, more
1999.0 A4 Avant 2.8 tip - hers
Past
- 2001 A4 1.8TQM Silver Black/black.(APR 91, 710N, Apikol snub, S4 grill)
- 97 A4 Pearl black/black 2.8QM *sold*
tehaudi is offline   Reply With Quote
Old 02-12-2009, 08:25 AM   #7
Banned
Account #: 29132
Default Are you talking the same thread? The fan thread is definately reverse
it's designed that way so that the fan doesn't come off due to pulley rotation.
Old 02-12-2009, 08:28 AM   #8
myers1.8TQ
I was lost, now I'm found
Account #: 147179
myers1.8TQ's Avatar
Default How I did it.
I put a long thin screw driver (red line) between the tabs (yellow arrow) and through a hole in the pulley. There is an allan bolt (blue arrow) behind the assembly that screws into the pulley that needs to be loosened and removed. Hope this helps.
Yah I know I got mad paintz skillz.
True story . . .
-Chris
rip AWKawf. Kawf still lives.
myers1.8TQ is offline   Reply With Quote
Old 02-12-2009, 08:33 AM   #9
tehaudi
Account #: 51968
Default *sigh* I had a long and hard problem getting mine off.
*hehe* Everyone said it was going to be reverse threaded, but after I broke the first aluminium tab trying to get it loose by pushing the wrench to the right and slamming my hand into a bloody mess i decided maybe it went the other way. I broke the tab holding the allen trying to go the other way too. So I gave up and ordered a spanner wrench. Waited for it, and took off the long bolt by turning towards the drivers side quarter panel and resting the spanner wrench against the A/C pulley(?). That would make it normal threaded correct?
In the pic, i broke the little tabs that are supposed to hold the metal pin that is supposed to stop the pulley from spinning.
Current
Past
Old 02-12-2009, 08:36 AM   #10
aluminumpork
Account #: 95023
Default I assume the 1.8T fan clutch setup is the same as the 30Vs?
18t, audi, b5, broke, clutch, fan, pull, remove, removing, s4, spanner, special, tool, volkswagen, wrench
Forum Jump
