Go Back   AudiWorld Forums > Audi Models > Audi A4 > A4 (B5 Platform) Discussion
Old 08-31-2008, 03:52 PM   #1
Kris Hansen
Chief of Goat control
Account #: 20
Kris Hansen's Avatar
Send a message via MSN to Kris Hansen
Default Crudola.. Discovered that the upper transmission line into the radiator is leaking slightly...
not sure about the lower one.. I was worried about these when I changed the radiator, I re-used the O-rings, which in retrospect, I suppose I should not have.. Luckily, it's easy to get at them without too much effort..
Question I have for myself and others.. anyone else installed a new rad, and not have problems with the automatic trans lines? it was a bitch getting them in, they're really tight..
Kris Hansen is online now   Reply With Quote
Old 08-31-2008, 04:49 PM   #2
Allroady DungBeetle
Account #: 35702
Allroady DungBeetle's Avatar
Default You need lube before putting it in there - it's really tight.
Wow that sounded bad huh??!! ;-P
The TRANSMISSION LINES need a little good lube on the o-rings so they can slide in there, if you go dry it will go hard and she'll often have seepage after since it can score the o-rings.
Many many have come and gone but life is too short to play with as many vehicles as you can!
----2012 A3 TDI premium plus, titanium pkg sport, nav and more.
----1993 Range Rover Classic with 4jg2 Isuzu turbo diesel power, lifted and locked - biodiesel burning beast.
----66 Mini Cooper S 27K miles & all original except cam, electronic ignition, oversize brakes and Yoko race tires.
----projects a-plenty - too many to count.
Allroady DungBeetle is offline   Reply With Quote
Old 08-31-2008, 05:22 PM   #3
4Driver4
Tech Guru
Account #: 43812
4Driver4's Avatar
Default Our old 1993 had a chronic leak there. I probably replaced those o-rings 5 times.
It would be good for a few months, then start leaking again. Eventually I got tired of it and installed a separate cooler.
4Driver4
Growing old is mandatory; growing up is optional.
1980 VW Scirocco (mid-life crisis car)
1983 Mazda RX-7 (revolutionary sports car)
2003 Mini Cooper S (just because)
1995 Mazda Miata, Superdupercharged(anti-Audi)
1999 Mazda Miata SSB (track beotch, no plate)
2003 GMC Yukon Denali XL (the anti-earth)
2004 Dodge Dakota (hey, at least it's stick and 4x4)
Old 08-31-2008, 06:26 PM   #4
@wesome
Account #: 145402
Default *unzips pants*... tell me more about what you want to lube and put in
If there were no rewards to reap,
No loving embrace to see me through this tedious path Ive chosen here,
I certainly wouldve walked away by now.
And I still may. and I still may. and I still may...
I'm gonna wait it out
@wesome is offline   Reply With Quote
Old 09-01-2008, 03:42 AM   #5
Kris Hansen
Account #: 20
Default That's what I'm afraid of, and I had the same thought as a solution....
Old 09-01-2008, 03:43 AM   #6
Kris Hansen
Account #: 20
Default I used a little Vaseline...
I have not looked at it yet, I wonder if the bolt loosened up.. *wishful thinking.. *
Old 09-01-2008, 05:50 AM   #7
Kris Hansen
Account #: 20
Default Upon further inspection, the top O-ring is damaged, not sure about the bottom..
I have not pulled it out yet, knowing that I need at least the upper, I'll go pick up a few of them, and then replace the lower regardless...
Old 09-01-2008, 06:46 AM   #8
4Driver4
Tech Guru
Account #: 43812
4Driver4's Avatar
Default OEM is teh best.
In all seriousness, buy the new o-rings from Audi. They are much harder than standard o-rings.
4Driver4
Old 09-01-2008, 07:09 AM   #9
Kris Hansen
Account #: 20
Default So what do you suggest till I can get them? Put it back together with the damaged ones?
I noticed that these o-rings do seem really firm, and was wondering about the chances of getting similar ones.. Most O-rings tend to be really soft..
Old 09-01-2008, 07:10 AM   #10
myers1.8TQ
I was lost, now I'm found
Account #: 147179
myers1.8TQ's Avatar
Default Yah when I replaced my radiator, . . .
It seemed like it had to be in the exact position and took forever to get them just fitting correctly. Then after that it was just as hard to keep it in-line and bolt them in. It was probably the hardest thing out of the whole job of replacing my radiator, fan, tran. fluid and everything else you have to do.
True story . . .
-Chris
rip AWKawf. Kawf still lives.
myers1.8TQ is offline   Reply With Quote
99, a4, a6, allroad, audi, leak, leaking, line, lineoring, lines, oring, radiator, ring, size, transmission
Forum Jump
