How do you install a fuel pressure gauge?
<center><img src="http://pictureposter.audiworld.com/72595/img_7718.jpg"></center><p>
Depressurize system, cut rail hose, put gauge in and there seems to be something else connected to the gauge.... Am I correct?
Yes, it is. :) Very nice car overall. It's not a AWM intake manifold or is it?
I'll look into passat projectors later. I might have to remove the fogs for good if the FMIC doesn't fit behind the stock bumper. Thanks for the info.
no. it is actually glue residue as I had taped the entire area
around where I was going to cut (so I could see my cut marks better). That was left behind when I removed the duct tape.
The hose is reinforced and tough to cut...but try to make straight cuts. I took out @ a 2" to 2 1/2" section on a straight section of the hose.
