Need help to bypass IMMOBILIZER...
Old 08-01-2006, 10:31 AM
CyberJedi's Avatar
Default Need help to bypass IMMOBILIZER...
can you give me advice on the following:
My Immobilizer is failing on my European 1997 B5 Audi A4, meaning sometimes it does not accept my key (any of my keys, actually). I need to try a few times and then it is okay, but this is annoying. Instead of buying a new immo unit, i would prefer to switch it off. Can you tell me if this is possible through software? I know car thieves might use the information but i am a legitimate owner of the car. Please use my email for sensitive information.
If you have any other ideas please let me know. Honestly, my car is not a main target for stealing anymore, as its value is not much. The shift-lock is adequate safety for me, with the Immo off.
The Fault Code:
Address 25 -------------------------------------------------------
Controller: 4A0 953 234 F
Component: IMMO AUZ9Z0T8932058 D77
Coding: 00000
Shop #: WSC 00066
1 Fault Found:
01176 - Key
07-10 - Signal to Low - Intermittent
Thank you in advance!
Sincerely, CyberJedi (at) freemail (dot) hu
Old 08-01-2006, 10:39 AM
Senior Member
qfrog@work's Avatar
Default maybe you need a new ignition cylinder reader coil
I'd imagine that you have immobilizer system 1 which we did not get stateside. None of our B5's had immobilizer systems enabled.
Gary Davis
08-24-2018 06:08 AM
Timfoilhat
A4 (B9 Platform) Discussion
10
03-14-2018 08:11 AM
Nick-blarg
Mid Atlantic Discussion
10-29-2004 10:26 AM
silentmurda
09-20-2002 01:56 PM
joestock
01-16-2002 08:54 PM
Quick Reply: Need help to bypass IMMOBILIZER...
