| A4 (B5 Platform) Discussion Discussion forum for the B5 Audi A4 produced from 1995-2001 B5 FAQ |
#1 | ||
AudiWorld Uber User
#2 |
Elder Member
If so, you shouldn't have to worry. Also, make sure you just crack the bleeder ever so slightly. Just open it enough to let it start dripping a fine line. It shouldn't be pouring out like water in a faucet.
#3 |
Member
But only if you let up on the pedal with the bleeder cracked open. If you shut the bleeder before releasing the pedal no air should enter the system.
Carson '01 VW GTI VR6 12V - SOLD! '01 S4 Tip Brilliant Black - will be sold for/converted to a 6MT, just a means to an end '06 A4 2.0TQT Arctic White (leased for wife) Audi Parts Consultant/ex-Certified VW/Audi Technician ACNA/NJ Chapter Vice President Next track event: ACNA/NJ Chapter NJMP, Thunderbolt Circuit, May 2009 ACNA/NJ Chapter Karting @ V-17, Feb. 25 7PM |
#4 |
AudiWorld Uber User
and I wasn't sure if this Lisle tool was accurately described as a "one man bleeder". It was less than $6 and I needed something small to put my Autohausaz order over $50, so I figured I'd take a look at it.
#5 |
AudiWorld Uber User
#6 |
Member
The ways to one man bleed are using either pressure via a forced bleeding system (VAG tool 5234 is what I use here at the job) or using vacuum....most hand vacuum pumps sold nowadays include a self brake bleeding kit.
#7 |
AudiWorld Uber User
#8 |
Sears sells a vacuum bleeder that is slightly cheaper, but somewhat of a pain in the *** to use. Instead of forcing fluid through the system by pushing it from the resevoir and out the bleed screw, you pull the fluid out by opening the screw and applying vacuum. You keep refilling the resevoir with the fresh stuff as the used fluid is bled out of the system.
The Motive bleeder is the more "idiot proof" way and a lot easier. Cheers,
--- 2002 A4 1.8TQM mod-free at the moment (gotta deal with that) Formerly...2001 A6 2.7T quattro 6sp w/GIAC X Before that...1999 A4 1.8T 5sp w/lots o mods |
#9 |
AudiWorld Uber User
#10 |
AudiWorld Expert
Most of them, you just press on a hose to the bleeder screw. The friction involved with keeping that hose on the bleeder screw is usually diminished severely as soon as that brake fluid hits it.
All tools are hammers, except screwdrivers, which are chisels.
| Tags |
| 2002, a4, audi, b7, bleed, bleeder, bleeding, brake, brakes, cup, instructions, lisle, tool, vacuum, z06 |
