| A4 (B5 Platform) Discussion Discussion forum for the B5 Audi A4 produced from 1995-2001 B5 FAQ |
#1 | ||
Junior Member
#2 |
FAQ Author
weight saving? maybe 40lbs or so if at all.. more a hassle than worth the work. one of the induktion cars had the sunroof removed and a custom cf into its place.. custom made and custom $$$$ big time as well.
Stephan B5 FAQ Creator Latest Mods: Clear Blinker Fluid, Heavy Duty Clutch Belt, Cross-Drilled Brake Lines, Engine Oil Bypass kit, and Chrome Muffler Bearings... IB broke the FAQ |
#3 |
Member
weld in sheet metal, sand, and paint it.
get the interior liner for an A4 without a sunroof, if having the slider for it bugs you.
-Jeff 2001.5 A4 1.8TQMSCC with APR SIII, EVO FMIC, Stoptech-less, STaSIS Tracksports 600F/750R ACNA MidOhio video Montreal race school and PDA Pocono video |
#4 |
Junior Member
I could put that in place of my room section. Yes/No?
#5 |
Member
#6 |
Elder Member
#7 |
Junior Member
#8 |
AudiWorld Expert
And you will have to fix the headliner inside and lots of things to fix to make it look like it never existed. Whats wrong with just leaving it shut?
------------------------------------------- ![]() Current: 2004 S4 No Warranty: 66K Fuel filter $45 67K Motor mount $200 67K Coil pack(s) $40*2 67K Window regulator $100 71K Battery $135 2003 TT 1.8T No Warranty: 50K Hazard Switch $50 Past: 1998 A4 1.8TQMS B6/7 S4 Hawk Pad part number update! Should no longer need to do the below anymore: How to modify C5 A6 Hawk pads for use in the B6/B7 S4 or B7 A4 |
#9 |
FAQ Author
ive seen that done in germany once where they cut 2 cars apart with nearly identical chassis numbers. one of the cars had some roof damage and they cut the roof off and welded the one from the other car back in but it was more of a hassle than worth anything
#10 |
AudiWorld Expert
...the rear pass quarter panel along with the area to the outside of the rain gutter that's one piece with that quarter panel, and the polished Al window trim (30v V6).
The total bill came to $1700 and some change, at a reputable local body shop, that's usually on the higher end of the price spectrum. I'd guess that to replace just the roof sheet metal shouldn't be more then $1000. Then there's the new headliner price to factor in, as well as little bits and pieces (new overhead console with no sunroof switch, etc...) FYI, for your reference.
All tools are hammers, except screwdrivers, which are chisels.
| Tags |
| car, damage, rid, sunroof, weight |
