16795 DTC taken care of
Old 09-19-2005, 08:16 AM
TristanP's Avatar
Default 16795 DTC taken care of
Before ordering the Combi valve, I looked at the vacuum lines coming out of it on Saturday. Sure enough, the intake side fabric was frayed at both ends and actually broken in the middle and at the end under the manifold. Replaced with some red (+5 hp) silicone tubing. No CELs in two cold starts. Like the old saying goes, start with the cheapest, easiest solution and go from there.
If the vac lines had checked out ok, the following info that ModifiedA4 has posted many times would be useful:
"In the event you have an A4 1.8T with engine code ATW with the DTC of 16795 - Secondary Air Injection system, Incorrect flow Detected, a leaking Combination valve could be the problem. A leaking valve causes exhaust gas to enter the secondary air system. The water from exhaust condensation travels through the entire secondary air injection system and if the temperature drops below 0 degrees Celsius the water will freeze. In most cases the water causes the air pump to corrode. Inspecting the combination valve will reveal the problem. If the Intake side of the valve is black, exhaust has entered the secondary air injection system"
Combi valve (06B 131 101 H) runs ~$120 at 1stvwparts.com and then the Secondary Air Injection pump gets expensive.
Old 09-19-2005, 08:29 AM
BSCA4's Avatar
Well done.
Old 09-19-2005, 08:32 AM
Member
Silver Streakin''s Avatar
nice work
Old 09-19-2005, 09:08 AM
RKA
AudiWorld Uber User
RKA's Avatar
Default That's interesting...
My car had this problem twice during it's warranty period. 1st one was on the house...second one was starting to become an issue, but the service manager couldn't confirm it (I could if I dropped it in chipped mode...because boost was bleeding out...somewhere). I never found the source, but more than likely it was exactly what you described. Where is this line attach to the intake manifold?
Old 09-19-2005, 09:36 AM
TristanP's Avatar
Default I'll try to get a pic tonight
It's a nipple facing towards the front of the car.
Old 09-19-2005, 10:00 AM
RKA
AudiWorld Uber User
RKA's Avatar
Don't forget to use the strobe!
Old 09-19-2005, 05:04 PM
TristanP's Avatar
Default 16795 DTC fix pics
The vacuum line we replaced runs from the combi valve (back of the cylinder head):
<img src="http://pictureposter.audiworld.com/20538/combi_n112_line.jpg">
To the N112 - secondary air injection solenoid valve - under the intake manifold:
<img src="http://pictureposter.audiworld.com/20538/combi_n112_line2.jpg">
Overview:
<img src="http://pictureposter.audiworld.com/20538/combi_n112_line3.jpg">
Runs from #3 to #8
<img src="http://pictureposter.audiworld.com/20538/sec_air_inj_system.jpg">
Old 09-19-2005, 05:19 PM
RKA
AudiWorld Uber User
RKA's Avatar
Default I get a twitch in my neck when I see these buried hoses!
Thanks!
Old 09-19-2005, 05:24 PM
TristanP's Avatar
Default Wasn't easy
Buried hoses may make the engine bay look cleaner, but once stuff breaks and needs to be replaced...ugh.
Old 09-19-2005, 06:33 PM
Member
::sigh:: that's the only line that I haven't replaced. one of these days...
Quick Reply: 16795 DTC taken care of
