Whats the function of tie rod ends and what happens if they go bad
Old 08-02-2005, 10:34 AM
Elder Member
eug (MK V)'s Avatar
Default Whats the function of tie rod ends and what happens if they go bad
best and worse case scenerio.
Just asking cuase my mechanic is fixing mine and said it was so bad (both sides) he wouldnt drive it.
I did have some clunking when like turning into parking spots.
Old 08-02-2005, 10:37 AM
leosphere's Avatar
Default mines were seriously bad after an accident. no grease and very loose. could have popped out..
if the ***** pop from their sockets, you won't be able to steer the car b/c they are what tie the steering rack to the hubs that hold the wheel from going straight. Once you remove one, that whole hub assembly freely swivles.
Old 08-02-2005, 10:39 AM
Elder Member
eug (MK V)'s Avatar
Oh, so in other words something bad could have happened?
Old 08-02-2005, 10:41 AM
leosphere's Avatar
extremely bad if it happened while you were driving.
AudiWorld Expert
S4iowa's Avatar
Default You would basicly have a wheel try to flip out and turn the car when you wan to go straight.
If the ball joint in the tie rod end were to come apart. It is also causing you a alignment problem and you will get bad tire wear. When they adjust the alignment (toe in/out) they are moving the tie rods.
Old 08-02-2005, 10:47 AM
ATL2.8Qmmm's Avatar
Default Ties together carrier and steering...longish
The tie rod ends (tre) connect the wheel upright to the steering mechanism. So when you turn the steering wheel, the pinion gear turns which the rack converts into a linear motion. The tie rods move side to side, pushing the wheels left or right. If you have a loose feeling steering wheel, it is probably the tie rod ends. If you hear crunchy noises when turning at slow speeds, it could be the tie rod ends (could also be bad control arms, because camber changes as steering increases). If the tre fails at any speed the wheel would be allowed to turn any which way it wanted. Crunchy noises, free play in wheel should be addressed as soon as possible.
Hope this helps
Old 08-02-2005, 10:49 AM
Elder Member
eug (MK V)'s Avatar
Default Yes it does thanks...but when you say loose steering
are you saying play in the wheel or just lack of tension?
I dont remember having any play in the steering wheel , but I do have a lot of torque steer.
Old 08-02-2005, 11:14 AM
MyaLover's Avatar
Default Not in the steering wheel, but if you have the car on jacks, the wheel will move side to side.
That's bad! Check the tech article on TREs and it shows how to check for play in the TRE.
Old 08-02-2005, 12:29 PM
shaners256's Avatar
Default Yeah, not good at all...had it happen to me in a work truck
when me and a buddy were out bombing around in places we shouldn't have been. Luckily we were moving slow, so nothing serious happened. It was just really hard to turn around to get out of the spot we were in, because the wheel kept flopping around.
chenishead
14
04-11-2015 04:01 PM
red90q
01-10-2009 04:31 PM
Chard
06-05-2008 05:41 AM
Pacs Legend
Audi 100 / A6 (C4 Platform)
11-17-2005 03:13 PM
Žob
02-05-2005 10:44 AM
Quick Reply: Whats the function of tie rod ends and what happens if they go bad
