Remote FOB Key Programming Instructions
Old 05-06-2005, 11:12 AM
BSK
BSK's Avatar
Default Remote FOB Key Programming Instructions
Programming remote unit
- Switch ignition ON.
- Lock vehicle mechanically at left front door using second key.
- Press "Open" button on first remote unit (key fob) once (to assign memory address to remote unit number one).
Note: The alarm horn will sound briefly each time the "Open" button is pressed to confirm the reception of the signal during this process.
- Wait six seconds after sending last signal, then press "Open" button again.
^ Doors will now unlock (remote unit is now programmed).
- Lock vehicle mechanically again using second key.
- Press "Open" button on second remote unit (key fob) twice at 1 second intervals (to assign memory address to remote unit number two).
- Wait six seconds after sending last signal, then press unlock button again.
^ Doors will now unlock (2nd transmitter is now programmed).
- Repeat procedure for additional remote units (key fobs) to assign memory addresses number 3 and 4 if necessary.
- Switch ignition OFF.
- Check each transmitter for proper function
Audi's Dad
04-14-2017 10:29 PM
mj_072
07-12-2006 10:09 PM
shrtbus(w/ cq)
03-24-2004 09:52 AM
kk_1.8t
12-18-2002 12:54 PM
CK NYoC
12-15-2001 09:55 PM
Quick Reply: Remote FOB Key Programming Instructions
