VAG-COM Discussion
Steering Angle Sensor / Steering Column Module (J527)
Old 06-11-2014, 05:10 PM
HereInOhio's Avatar
Default Steering Angle Sensor / Steering Column Module (J527)
I have a 2003 Cabriolet 1.8t. Most of the electronics are not working, roof, windows, remote, wipers, turn signals, ect. I thought it was the CCM based on some research and replaced it but that didn't help. I finally found my cable so I ran the scan and this is what I came up with (after clearing all of the codes that were stored). Keep in mind the battery died on the car, it was jumpped, then the battery was replaced. Not sure if that is relevant to the problem. I see two main problems, the steering angel sensor and steering column module. I looked into this and it said most likely there are optic "eyes" that get dirty and need to be cleaned or the angle sensor needs replaced. I also heard it can be reset. Does anyone know where I can start to diagnosis this?
Thanks in advance!
Chassis Type: 8H (8H - Audi Cabrio B6/B7 (2003 > 2009))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 26 36 37 45 46 55 56 57
63 65 67 73 75 76 77
VIN: WAUAC48H23K027820 Mileage: 266640km/165682miles
Address 01: Engine Labels: 06B-909-518-AMB.lbl
Part No SW: 8E0 909 518 AF HW: 8E0 909 018 A
Component: 1.8L R4/5VT G 0003
Coding: 0016584
Shop #: WSC 00672 785 00200
VCID: 74E9D66C1490E0BE8FF-5178
1 Fault Found:
18107 - Powertrain Data Bus
P1699 - 008 - Missing Message from Steering Wheel Electronics
Readiness: 0110 1101
Address 02: Auto Trans Labels: 01J-927-156.lbl
Part No: 01J 927 156 FF
Component: V30 01J 1.8l5VT USA 3011
Coding: 00001
Shop #: WSC 04940
VCID: 75EFEB684FEAF9B6B81-515A
No fault code found.
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517 G
Component: ABS/ESP front 2328
Coding: 04279
Shop #: WSC 00672
VCID: 2C590E0CDC20F87E17F-513C
1 Fault Found:
18036 - Powertrain Data Bus
P1628 - 35-00 - Missing Message from Steering Angle Sensor
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 L
Component: A4 Klimaautomat 1116
Coding: 00100
Shop #: WSC 00672
VCID: 2A550814D6D4E64EE53-515A
Address 15: Airbags Labels: 8H0-959-655-84.lbl
Part No: 8H0 959 655 B
Component: Airbag 8.4EC 1015
Coding: 0010105
VCID: 3977275873725DD69C9-5178
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8H0 920 950 E
Component: KOMBI+WEGFAHRS. RB4 D16
Coding: 02201
Shop #: WSC 03055
VCID: 2E5D0404EA3C8A6E39B-5178
WAUAC48H23K027820 AUZ6Z0C0062338
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00070
Shop #: WSC 00672
VCID: 040986AC1430D03EBFF-4B4A
Address 56: Radio Labels:
VCID: 55AF8BE8AC2A99B6981-4ECA
Note: Excessive Comm Errors
Address 63: Entry Assist,D Labels: None
Part No: 8H0 959 760 A
Component: EasyEntry F H11 X023
Coding: 00005
Shop #: WSC 00065
VCID: 356F2B680F6AB9B6781-4B32
1 Fault Found:
00466 - Control Module for Steering Column Electronics (J527)
49-00 - No Communications
Address 73: Entry Assist, P Labels: None
Component: EasyEntry BF H11 X023
Coding: 00005
Shop #: WSC 00065
VCID: 356F2B680F6AB9B6781-4B18
1 Fault Found:
End ---------------------------------------------------------------------
Old 06-12-2014, 05:53 AM
jakematic's Avatar
First, thank you for posting a complete Auto-Scan as it always helps
My biggest concern is module 16 (steering wheel) is missing from the scan.
First thing I'd do is run an Optical Bus diagnostic to see if any other module is having a problem.
I suspect the radio has something to do with it, but that's just a guess at this point.
Next step is to isolate the issue and check all wiring and optical connections.
If that doesn't help, you might need to replace J527.
That might require immobilizer pairing which can only be done by a dealer or specially authorized shop though.
Old 06-12-2014, 07:37 AM
HereInOhio's Avatar
I tried to run the module scan on the steering wheel and it said it didn't communicate. I didn't know if that could be if the sensor is bad or if the module is bad. If it could be the sensor I wanted to try to reprogram it before replacing it.
I pulled the radio and checked the 10 amp fuse, it was fine. The radio works fine besides the fact you can turn it on ANY time.
As far as the Optical Bus scan I beleive that is for CAN cars only which this one is before that time from what I researched. I will try anyways when I go home but don't think it will get far. The KII cable had a green light which should mean both K lines are ok and info is flowing completely.
I can probably get the steering angle sensor and the module fairly cheap, do you know how I can tell if it will need to be taken to the dealership to have paired?
Old 06-12-2014, 07:51 AM
jakematic's Avatar
BAH! We've already had that conversation, sorry
I'm kind of shooting in the dark on this, so hopefully others can give you more complete information, and you may get better support on the thread you started at Ross-Tech.
paddymonkey
VAG-COM Discussion
06-29-2019 01:49 PM
juhasztwins
07-21-2013 07:31 AM
Boostedmx606
10-15-2012 10:46 AM
huskul
A4 (B8 Platform) Discussion
11-20-2011 07:14 PM
chris.sargent
VAG-COM Discussion
10-13-2009 01:57 AM
Quick Reply: Steering Angle Sensor / Steering Column Module (J527)
