Is there no fuel pressure sensor?
Thought I'd found it by searching Bentley but only on the V10 and another production code (=newer) engine. Mine's the BFM as are all US 2004s.
Trying to run down codes including a trail to fuel pumps and would love to log pressure, pump status, etc. for each, but I searched last night and no luck.
Do all these cars (4.2s) need the EGR Adaptation MP talked of in the past?
More details later, sorry gotta run...
Tom
Tom
I can't find one anywhere in the (non encrypted) label files or the parts list.
Have a look at these general MVBs: http://www.ross-tech.com/vag-com/m_blocks/
If you don't find one, you know where to ask...
Thanks, Jake. Yes, I know who. Either some EE who can speed through a wiring diagram like we read the comics; or my Laird Uwe who might know the correlation of these codes - they all occur together and the car stalls. She was kind enough to provide a full set just now, for my immediate use. Didn't quite stall as my 11-year old is getting good at save/clear codes! It is happening with increasing frequency, every 40 miles or so.
Please to enjoy le codes:
(sorry my email hacks up the formatting, I tried to fix it)
Thursday,22,May,2014,15:19:49:64698 VCDS Version: Release 12.12.2
Address 01: Engine Labels: 077-910-560-BFM.LBL Control Module Part Number: 4E0 910 560 A HW: 4E0 907 560 Component and/or Version: 4.2L V8/5V G 0050 Software Coding: 0007773 Work Shop Code: WSC 98765 666 30770 VCID: 1F4D5514CD4166E682D-5124
6 Faults Found:
17981 - Left Engine Mount Solenoid Valve (N144) P1573 - 004 - Open Circuit
17538 - Fuel Trim; Bank 2 (Mult) P1130 - 001 - System too Lean - Intermittent
17536 - Fuel Trim; Bank 1 (Mult) P1128 - 001 - System too Lean - Intermittent
16487 - Mass Air Flow Sensor (G70) P0103 - 008 - Signal too High
18663 - Oxygen (Lambda) Sensor B1 S1 P2231 - 004 - Signal Shorted to Heater Circuit 18666 - Oxygen (Lambda) Sensor B2 S1 P2234 - 004 - Signal Shorted to Heater Circuit
Readiness: 0000 1101
Then there are usually these codes as well, not sure if caused by the stall or if they "mean something":
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 E HW: 09E 927 156 A
Component: AG6 09E 4,2L5V USA 0060
Coding: 0000002
Shop #: WSC 02353 785 00200
VCID: 24475AF8E727453EDFF-8071
1 Fault Found:
18265 - Load Signal
P1857 - 000 - Error Message from ECU - Intermittent
Freeze Frame:
RPM: 1312 /min
RPM: 1216 /min
RPM: 1792 /min
(no units): 38.0
(no units): 54.0
Temperature: 77.0°C
T.B. Angle: 14.1°
Voltage: 13.12 V
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 A HW: 4E0 614 517 E
Component: ESP 5.7 allrad H29 0420
Coding: 0007597
Shop #: WSC 03419 000 00000
VCID: 214953ECF8355016B49-8074
1 Fault Found:
18265 - Load Signal
P1857 - 000 - Error Message from ECUThe first two codes are almost always there.
Anytime the 16487 MAF P0103 occurs the car stalls. It only occurs at or near idle, usually after driving at 45-55 MPH for 5-10 minutes.
Once, the car stalled without the last two, but usually they are set.
I know there is a common connector where these converge that's broken! Or at least they are related somehow.
Also that big pucklike throttle control valve makes me nervous. Can't find much info on it.
Another thought I'm entertaining is to swap the old MAF back in. Bosch doesn't send out defective ECUs right? I fixed the EGR lines and airbox since then....
Naturally, and as usual; thanks in advance for any help.
Going out to look for vacuum leaks. You can still do that with propane, right? I've got a big full tank that won't connect to my grill. Hmmmm.
-Tom
6 Faults Found:
Coding: 0000002
1 Fault Found:
18265 - Load Signal
Freeze Frame:
RPM: 1312 /min
RPM: 1216 /min
RPM: 1792 /min
(no units): 38.0
(no units): 54.0
Temperature: 77.0°C
T.B. Angle: 14.1°
Voltage: 13.12 V
Coding: 0007597
1 Fault Found:
18265 - Load Signal
-Tom
Post it up over there - you're verified IIRC.
No offense, but you're not likely to find anyone here who knows, yet.
I'm one of the few there who know the C and D chassis, but there are some top notch guys who have access to a lot of info - and experience.
Propane you say?
No propane accessories? Dammit BobbyTom !
Reminds me of my grandfather 'testing' for gas leaks with a propane torch or a match.
Propane you say?
Good idea, I will; I thought they monitored AW for mention of VCDS...
FWIW, I liberally sprayed the manifold/block juncture with CRC MAF cleaner without result. Then I thought I better verify its effect , so I disconnected the vac tube from the B/W check valve and sprayed into the tube going straight into the manifold (I guess)... it took a surprisingly large amount to affect the idle. I then took off the fuel pressure regulator tube and it had virtually no effect.. I sprayed first a little then a lot into the tube and finally got a slight reaction. No DTCs triggered by all this...
One old school test I performed was manifold vacuum; it was not exactly steady at idle, but varied +/- maybe five pounds. Measured at FPR tube. Revved to ~4000 RPM but vac performed as expected, smooth and up & down.
Very tired and sore. And up too late...
Tom
Tom
Have you checked the wiring from the maf to ecu for continuity and resistance as suggested in the other thread.
Its unlikely that the new maf is faulty but not impossible.
If the cable from the maf is dodgy then its entirely possible that the ecu is getting a reading thats outside the normal operating parameters and it doesn't know how to respond.
Check the wiring and if your satisfied with it, log the maf when your driving.
I deoxited the large plug to the ECU in the cowl. I will have to educate myself on how to determine which is which so I can "ohm it out".
I'm attaching one file (EDIT: or not...) which I hope are useful. It DID stall once when I was data-logging, I hope someone can figure which and it's useful.
So far all I can report re the health of the new MAF is in measuring block 002 at 5000 RPM, my wife thinks the highest she saw was 280. Probably 80% throttle.
I've got all these logs I dunno how to post. Or if they would even be helpful.
The evap one @ 80 MPH was the insufficient vacuum. Just level ground, nothing remarkable
All the other logs are too big for this forum.
CSV files show as "Invalid File"...
Steep learning curve with something this complicated, I suppose.
And yes, I know I'll have to get under it at some point...
Tom
Tom
some logs
Thursday,22,May,2014,15:06:36:64698 VCDS -- Windows Based VAG/VAS Emulator VCDS Version: 12.12.2.0 Data version: 20140212
Mileage: 189565 Repair Order: SJV OK
Address 01: Engine (4E0 910 560 A)
15:06:15 Group 002: General 640 /min Engine Speed (G28) 20.3 % Engine Load 4.10 ms Injection Timing 7.56 g/s Mass Air Flow Sensor (G70)
15:06:15 Group 032: Lambda Control (Mixture Adaptation) 1.9 % Adaptation (Idle) Bank 1 Sensor 1 6.3 % Adaptation (Partial) Bank 1 Sensor 1 1.9 % Adaptation (Idle) Bank 2 Sensor 1 6.3 % Adaptation (Partial) Bank 2 Sensor 1
15:07:00 Group 002: General 680 /min Engine Speed (G28) 20.3 % Engine Load 4.10 ms Injection Timing 7.31 g/s Mass Air Flow Sensor (G70)
15:07:00 Group 033: Lambda Control 7.0 % Lambda Control Bank 1 Sensor 1 1.580 V Sensor Voltage Bank 1 Sensor 1 0.8 % Lambda Control Bank 2 Sensor 1 1.560 V Sensor Voltage Bank 2 Sensor 1
15:07:00 Group 034: Lambda Control (Aging Check: Bank 1 Sensor 1) 640 /min Engine Speed (G28) 445.0°C Catalytic Converter Bank 1 Temp. 0.353 Dynamic Factor Bank 1 Sensor 1 Test OFF Result Lambda Aging
15:07:23 Group 002: General 640 /min Engine Speed (G28) 19.5 % Engine Load 3.69 ms Injection Timing 6.08 g/s Mass Air Flow Sensor (G70)
15:07:23 Group 033: Lambda Control -0.8 % Lambda Control Bank 1 Sensor 1 1.520 V Sensor Voltage Bank 1 Sensor 1 -7.8 % Lambda Control Bank 2 Sensor 1 1.520 V Sensor Voltage Bank 2 Sensor 1
15:07:23 Group 034: Lambda Control (Aging Check: Bank 1 Sensor 1) 680 /min Engine Speed (G28) 440.0°C Catalytic Converter Bank 1 Temp. 0.353 Dynamic Factor Bank 1 Sensor 1 Test OFF Result Lambda Aging
15:07:34 Group 002: General 680 /min Engine Speed (G28) 18.8 % Engine Load 3.28 ms Injection Timing 5.42 g/s Mass Air Flow Sensor (G70)
15:07:34 Group 034: Lambda Control (Aging Check: Bank 1 Sensor 1) 640 /min Engine Speed (G28) 440.0°C Catalytic Converter Bank 1 Temp. 0.353 Dynamic Factor Bank 1 Sensor 1 Test OFF Result Lambda Aging
15:07:34 Group 035: Lambda Control (Aging Check: Bank 2 Sensor 1) 680 /min Engine Speed (G28) 440.0°C Catalytic Converter Bank 2 Temp. 0.353 Dynamic Factor Bank 2 Sensor 1 Test OFF Result Lambda Aging
15:07:44 Group 002: General 640 /min Engine Speed (G28) 19.5 % Engine Load 3.28 ms Injection Timing 5.31 g/s Mass Air Flow Sensor (G70)
15:07:44 Group 036: Lambda Control (Sensor Readiness - After Catalyst) 0.695 V Sensor Voltage Bank 1 Sensor 2 B1-S2 OK Result Lambda Availability 0.635 V Sensor Voltage Bank 2 Sensor 2 B2-S2 OK Result Lambda Availability
15:07:44 Group 037: Lambda Control (Delta Lambda Bank 1) 19.5 % Engine Load 0.695 V Sensor Voltage Bank 1 Sensor 2 -0.004 Delta Lambda Bank 1 Sensor 2 B1-S1 OK Result Delta Lambda B1
OrlandoDave
A4 (B7 Platform) Discussion
12-26-2023 01:19 AM
skapan
06-12-2008 05:34 PM
big_anthoiny
10-10-2007 01:25 PM
