17536 & 17538 (P1130 P1128) too lean (multi) persist
I thought I'd found the problem with the replacement of the vac lines to the EG valves. Nope.
Only other clues are a persistent 18265 (P1857) "error message from ECU- intermittent"
Next step is check fuel injector o-rings (is there an easy method)?
Lambda load test (although it sounds tortuous to the transmission)
If I can find the O2 sensor connectors I'll try to measure volts & ohms; thought I'd found an easy route under the pass side noise insulation but no measurements possible..
Since I have no easy way to measure fuel pressure is there a VCDS measuring block that's reliable for that?
I have (since trying to cure these codes) changed spark plugs, sealed air box, checked vac lines and replaced a couple. Oh and a new Bosch MAF from AudipartsUSA
Misha says to check the harness to the MAF but other than visually how does one do this?
TIA,
Tom
full scan with the broken vac line to EGR valve:
Friday,16,May,2014,15:09:46:64698 VCDS -- Windows Based VAG/VAS Emulator VCDS Version: 12.12.2.0 Data version: 20140212
VIN: WAUML44EX4N001183
Mileage: 304590km-189263mi
Chassis Type: 4E (4E0) Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 19 25 34 36 37 38 42 46 47 4F 52 53 55 56 61 62 65 72 75 76
00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 05-Acc/Start Auth. -- Status: OK 0000 06-Seat Mem. Pass -- Status: OK 0000 07-Control Head -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: OK 0000 0E-Media Player 1 -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 34-Level Control -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: OK 0000 38-Roof Electronics -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: Malfunction 0010 55-Xenon Range -- Status: OK 0000 56-Radio -- Status: Malfunction 0010 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 65-Tire Pressure -- Status: Malfunction 0010 72-Door, Rear Right -- Status: OK 0000 75-Telematics -- Status: Malfunction 0010 76-Park Assist -- Status: Malfunction 0010
-------------------------------------------------------------------------------Address 01: Engine Labels: 077-910-560-BFM.lbl Part No SW: 4E0 910 560 A
Component: 4.2L V8/5V
Serial number: AUX3Z0C2512094
Revision: 00000000
Coding: 0007773 Shop #: WSC 98765 666 30770 VCID: 1F4D5514CE4166E682D-804A
1 Fault Found: 17981 - Left Engine Mount Solenoid Valve (N144) P1573 - 004 - Open Circuit Readiness: 0000 0101
-------------------------------------------------------------------------------Address 02: Auto Trans
Part No SW: 4E0 910 156 E
Component: AG6 09E 4,2L5V USA 0060 Coding: 0000002 Shop #: WSC 02353 785 00200 VCID: 24475AF8E727453EDFF-8071
No fault code found.
-------------------------------------------------------------------------------Address 03: ABS Brakes
Part No SW: 4E0 910 517 A
Component: ESP 5.7 allrad H29 0420 Coding: 0007597 Shop #: WSC 03419 000 00000 VCID: 214953ECF8355016B49-8074
1 Fault Found: 18265 - Load Signal P1857 - 000 - Error Message from ECU - Intermittent
-------------------------------------------------------------------------------Address 05: Acc/Start Auth.
Part No SW: 4E0 910 131
Component: FBS AUDID3 H02 0110 Revision: 01103502 Serial number: AUX3Z0C2512094 Coding: 0263168 Shop #: WSC 02313 785 00200 VCID: D8BFBE086BEF51DE037-808D
Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV
-------------------------------------------------------------------------------Address 06: Seat Mem. Pass
Part No SW: 4E0 910 760 C
Component: Sitzmemory BFS H06 0050 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 3940576 Shop #: WSC 02313 785 00200 VCID: 234559E4E2294206A65-8076
-------------------------------------------------------------------------------Address 07: Control Head
Part No SW: 4E0 910 729 B
Component: Interfacebox
Revision: 00000000 Serial number: 346D8037502020 Coding: 0000103 Shop #: WSC 02353 785 00200 VCID: 275D4DF49611AE26FAD-8072
Subsystem 1 - Part No: 4E0 910 611 Component: E0380 BedienteilH01 0050
Subsystem 2 - Serial number: 00000000062751
Subsystem 3 - Serial number: 0104.04.080000000100010133ÿ
Subsystem 4 - Serial number: 010133ÿ
-------------------------------------------------------------------------------Address 08: Auto HVAC
Part No SW: 4E0 910 043
Component: KLIMAAUTOMAT
Serial number: 00000000013677
Revision: 00000014
Coding: 0037185 Shop #: WSC 02313 785 00200 VCID: DABBA40015E343CE353-808F
Subsystem 1 - Part No: 4E0 910 772 Component: Sitzluefter FS H05 010
Subsystem 2 - Part No: 4E0 910 772 Component: Sitzluefter BFS H05 010
Subsystem 3 - Serial number: 898053000
Subsystem 4 - Serial number: HO10032003065A000000000208ÿ†89
Subsystem 5 - Serial number: 000208ÿ†898053000
Subsystem 6 - Serial number:
Subsystem 7 - Serial number: 65A000000000198ÿ
2 Faults Found: 00729 - Potentiometer in Positioning Motor for Right-Hand Central Vent (G137) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 197 Mileage: 304071 km Time Indication: 0 Date: 2014.05.08 Time: 17:53:25
Freeze Frame: Voltage: 13.40 V (no units): 207.0 (no units): 255.0
00728 - Potentiometer in Positioning Motor for Left-Hand Central Vent (G136) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 197 Mileage: 304097 km Time Indication: 0 Date: 2014.05.08 Time: 20:31:43
Freeze Frame: Voltage: 12.60 V (no units): 0.0 (no units): 0.0
-------------------------------------------------------------------------------Address 09: Cent. Elect.
Part No SW: 4E0 910 279 E
Component: ILM Fahrer
Coding: 0111003 Shop #: WSC 24103 444 84355 VCID: 2A5BB4C08503934EE53-807F
Subsystem 1 - Part No: 4E1 910 113 Component: Wischer WWS D3 H30 0320 Coding: 00000030 Shop #: WSC 24103
-------------------------------------------------------------------------------Address 0E: Media Player 1
Part No SW: 4E0 910 111
Component: CD-Changer
Serial number: AUZ5ZBC1012376 Shop #: WSC 00000 000 00000 VCID: D6A3B03061FB67AE11B-8083
2 Faults Found: 00384 - Optical Databus 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 209 Mileage: 304543 km Time Indication: 0 Date: 2014.05.15 Time: 21:17:17
Freeze Frame:
10
Bin. Bits:
02261 - Data Medium 014 - Defective - Intermittent Freeze Frame: Fault Status: 00101110 Fault Priority: 7 Fault Frequency: 3 Reset counter: 210 Mileage: 304563 km Time Indication: 0 Date: 2014.05.16 Time: 07:41:38
Freeze Frame: Text: 0000B80A
-------------------------------------------------------------------------------Address 15: Airbags Labels: 4E0-910-655-84.lbl Part No SW: 4E0 910 655 A
Component: Airbag 8.4E+
Coding: 0530707 Shop #: WSC 02353 785 00200 VCID: 24475AF8E727453EDFF-8071
-------------------------------------------------------------------------------Address 16: Steering wheel
Part No SW: 4E0 910 549
Component: Lenksäulenmodul H09 0030 Coding: 0012241 Shop #: WSC 02313 785 00200 VCID: E5C187FC2C9DFC36881-80B0
Subsystem 1 - Part No: XXXXXXXXXXX Component: Lenkradmodul
-------------------------------------------------------------------------------Address 17: Instruments
Part No SW: 4E0 910 900
Component: KOMBIINSTR. VDO H42 0060 Revision: D07 Serial number: AUDID3C2000250 Coding: 0000223 Shop #: WSC 03213 444 04780 VCID: DCB7A2181FD7BDFE27F-8089
-------------------------------------------------------------------------------Address 19: CAN Gateway
Part No SW: 4E0 910 468 A
Component: Gateway
Revision: 06 Serial number: 50003222012801 Coding: FCFE7BDD1B2304 Shop #: WSC 98765 666 30770 VCID: 264340F0911BB72EC1B-8073
-------------------------------------------------------------------------------Address 25: Immobilizer
XXXXXXXXXXX ELV
-------------------------------------------------------------------------------Address 34: Level Control
Part No SW: 4E0 910 553 H
Component: LUFTFDR.-CDC
Coding: 0015510 Shop #: WSC 03419 444 82747 VCID: 285F4EC89B0FA15EF37-807D
-------------------------------------------------------------------------------Address 36: Seat Mem. Drvr
Component: Sitzmemory FS H06 0050 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4071650 Shop #: WSC 02313 785 00200 VCID: 234559E4E2294206A65-8076
-------------------------------------------------------------------------------Address 37: Navigation
Part No SW: 4E0 910 887 N
Component: MNS US
Revision: 00000000 Serial number: 355DR037503587 Shop #: WSC 02353 785 00200 VCID: 387F9E884BAF31DE637-806D
-------------------------------------------------------------------------------Address 38: Roof Electronics
Part No SW: 4E0 910 135 A
Component: Dachknoten D3
Serial number: 00000621300028 Coding: 0003989 Shop #: WSC 24103 444 52497 VCID: 1D316F1CC44D74F6901-8048
-------------------------------------------------------------------------------Address 42: Door Elect, Driver
Part No SW: 4E1 910 802
Component: Türsteuer.FS BRM004 0080 Coding: 0028196 Shop #: WSC 02313 785 00200 VCID: DEB3A81009CBAFEE49B-808B
-------------------------------------------------------------------------------Address 46: Central Conv.
Part No SW: 4E0 910 289 A
Component: Komfortgeraet
Revision: 00300003 Serial number: W040303250172 Coding: 0065054 Shop #: WSC 02353 785 00200 VCID: 275D4DF49611AE26FAD-8072
Subsystem 1 - Part No: 4E0 907 719 Component: Neigungssensor H02 0020
1 Fault Found: 01134 - Alarm Horn (H12) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 254 Reset counter: 169 Mileage: 148966 km Time Indication: 0 Date: 2008.03.16 Time: 14:41:17
-------------------------------------------------------------------------------Address 47: Sound System
Part No SW: 4E0 910 223 A
Component: DSP-Amp.-High
Revision: üˆ Serial number: h Coding: 5636099 Shop #: WSC 00049 000 00000 VCID: 1B356104DA597AC66E5-804E
-------------------------------------------------------------------------------Address 4F: Centr. Electr. II
Part No SW: 4E0 910 280
Component: ILM Beifahrer
Revision: Serial number: 00000000011192 Coding: 0010111 Shop #: WSC 02313 785 00200 VCID: DDB1AF1C04CDB4F6501-8088
Subsystem 1 - Part No: 4E0 910 511 A Component: UGDO HL US
-------------------------------------------------------------------------------Address 52: Door Elect, Pass.
Component: Türsteuer.BF BRM004 0080 Coding: 0028196 Shop #: WSC 02313 785 00200 VCID: DEB3A81009CBAFEE49B-808B
-------------------------------------------------------------------------------Address 53: Parking Brake
Part No SW: 4E0 910 801 B
Component: EPB A22HC020
Revision: A22HC020 Coding: 0000532 Shop #: WSC 54321 210 01865 VCID: 1E336810C94B6FEE89B-804B
2 Faults Found: 02596 - Rear Brake Pads Worn 002 - Lower Limit Exceeded Freeze Frame: Fault Status: 01100010 Fault Priority: 6 Fault Frequency: 254 Reset counter: 63 Mileage: 299296 km Time Indication: 0 Date: 2014.03.08 Time: 09:54:37
Freeze Frame: Voltage: 12.11 V Count: 60
02596 - Rear Brake Pads Worn 008 - Implausible Signal Freeze Frame: Fault Status: 01111000 Fault Priority: 6 Fault Frequency: 3 Reset counter: 63 Mileage: 298080 km Time Indication: 0 Date: 2014.02.21 Time: 11:59:29
Freeze Frame: Voltage: 13.35 V Count: 61
-------------------------------------------------------------------------------Address 55: Xenon Range
Part No SW: 4E0 910 357
Component: Pre-AFS
Serial number:
Revision: 00000001
Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: E2CB9CE03DB38B0E6D3-80B7
-------------------------------------------------------------------------------Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541
Component: TUNER EU/US/RDW H41 0180 Revision: 00000000 Serial number: 304CH037520918 Coding: 0000002 Shop #: WSC 02353 785 00200 VCID: DDB1AF1C04CDB4F6501-8088
1 Fault Found: 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 66 Reset counter: 204 Mileage: 0 km Time Indication: 0
-------------------------------------------------------------------------------Address 61: Battery Regul.
Part No SW: 4E0 910 181 C
Component: J0644 BEM
Revision: 00000000 Serial number: 00000000012125 Shop #: WSC 03213 444 65458 VCID: 204F56E8F33F591EBB7-8075
Subsystem 1 - Part No: 000 915 105 AK Component: von VA0 BOSCH12345 Coding: 303030393135313035414B564130424F5343483132333435 Shop #: WSC 54321 210 01865
-------------------------------------------------------------------------------Address 62: Door, Rear Left
Part No SW: 4E0 910 802
Component: Türsteuer.HL BRM004 0080 Coding: 0028196 Shop #: WSC 02313 785 00200 VCID: DDB1AF1C04CDB4F6501-8088
-------------------------------------------------------------------------------Address 65: Tire Pressure
Part No SW: 4E0 910 273
Component: Reifendruck 2
Coding: 0212127 Shop #: WSC 02313 785 00200 VCID: DFCD95140EC1A6E642D-808A
2 Faults Found: 01477 - System Switched Off 000 - -Freeze Frame: Fault Status: 01100000 Fault Priority: 4 Fault Frequency: 253 Reset counter: 171 Mileage: 279226 km Time Indication: 0 Date: 2013.06.20 Time: 12:25:12
Freeze Frame: Speed: 0.0 km/h Temperature: 32.0°C Error Code: 0 Not Recogn. Not Recogn. Not Recogn. Not Recogn.
01521 - Sensor for Tire Pressure 004 - No Signal/Communication - MIL ON Freeze Frame: Fault Status: 11100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 179 Mileage: 279240 km Time Indication: 0 Date: 2013.06.27 Time: 09:05:59
Freeze Frame: Speed: 85.0 km/h Temperature: 28.0°C Error Code: 0 Not Recogn. Not Recogn. Not Recogn. Not Recogn.
-------------------------------------------------------------------------------Address 72: Door, Rear Right
Component: Türsteuer.HR BRM004 0080 Coding: 0028196 Shop #: WSC 02313 785 00200 VCID: DDB1AF1C04CDB4F6501-8088
-------------------------------------------------------------------------------Address 75: Telematics
Part No SW: 4E0 910 616
Component: Telematik USA1
Revision: 00000002 Serial number: 0000ATD3001323 Coding: 0000005 Shop #: WSC 03419 444 53463 VCID: E0CF96E830BF991E7B7-5106
1 Fault Found: 01531 - Emergency Battery 002 - Lower Limit Exceeded - MIL ON
-------------------------------------------------------------------------------Address 76: Park Assist
Part No SW: 4E0 910 283
Component: Parkhilfe 8-Kan H07 0030 Coding: 0001208 Shop #: WSC 02353 785 00200 VCID: E0CF96E833BF991E7B7-80B5
2 Faults Found: 01628 - Sensor for Parking-Aid; Front Mid-Left (G254) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 177 Mileage: 279226 km Time Indication: 0 Date: 2013.06.26 Time: 21:15:52
01627 - Sensor for Parking-Aid; Front Mid-Right (G253) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 177 Mileage: 279226 km Time Indication: 0 Date: 2013.06.26 Time: 21:15:53
End ---------------------------------------------------------------------
Address 01: DTCs cleared
TIA,
Tom
Revision: 00000000
Revision: 00000014
Freeze Frame:
10
Bin. Bits:
Component: Gateway
XXXXXXXXXXX ELV
Component: MNS US
Component: Pre-AFS
Serial number:
Revision: 00000001
- Tone it out
- Continuity / short testing
- Overlay harness
- Twist/move while looking at measuring blocks
You'll need a wiring diagram to ensure where the traces go.
See also Dr Peter's tip on this.
Thanks, Jake; but what does "tone it out" mean, and is an overlay harness some kit type thing or a junkyard/new one? Also. this assumes I can get at the other end of the harness.
After seeing how brittle some of the vac tubing was I hate to "wiggle or twist" the harness!
I see it must be done, though.
Had a'96 E320 whose harness was set to disintegrate at 250k miles. What a mess.
Tom
Tom
gohardRgohome
01-14-2008 05:35 AM
andysprague
09-24-2007 05:32 PM
Mr.D-'97 A4q 12v
12v V6 Discussion
12
02-15-2004 04:44 PM
PearlA4_1
12v V6 Discussion
01-24-2004 04:42 PM
SmokinS4™
20
06-30-2003 05:15 PM
