Harsh winter
Harsh winter
Had to change both front coils due to potholes around the city. Was fairly easy to do.
18 mm top ball joint, 21mm lower strut bolt. 18 mm sway bar link, 21 mm tie rod end, 13 mm strut to top bolts. Be sure to have a pitman arm puller and a way to put the tie rod and ball joint back, I used an impact gun. To take out the strut is a bit tricky, you'll need to move the ABS wires aside and pull strait toward yourself.
Pacs Legend
Audi 100 / A6 (C4 Platform)
05-23-2008 07:27 AM
quattrokyle
09-10-2007 06:00 AM
