Transmission
Old 04-19-2014, 01:40 PM
AudiQC's Avatar
Default Transmission
Slipping from 1st to 2nd but not all time, just if i push it hard....I should say that sometimes it makes bizar reaction when shifting in reverse.......Is it the converter or the oil ? It has 200 000 miles. Almost 3 years ago i had the oil change.
Old 04-19-2014, 05:48 PM
5v/cyl's Avatar
Is it fine in TIP mode? If so then do a fluid change. Cheap solution if that is the problem. How many miles on fluid that is in there?
Old 04-20-2014, 04:08 AM
amiram's Avatar
Default transmission servicing
Before you replace the transmission fluid and filter , Check the transmission fluid level. If the transmission oil is missing, check for leaks. Check the fluid condition (color, smell, sediment,end Chips).
Old 04-20-2014, 04:42 AM
AudiQC's Avatar
Thanks for the "hint" ....the oil is about 50 000 miles old.
Yes ! good idea, i will have the oil level cheched next week.
And Happy Easter to all "alroaders"
Bariukas
23
12-17-2016 10:59 PM
am_ver
10-22-2013 11:37 AM
ErnesTT
TT (Mk1) Discussion
02-26-2009 06:18 AM
BigThistle
08-31-2003 04:47 AM
Larry
09-13-1999 11:03 AM
Quick Reply: Transmission
