Rear drivers side suspension griding noise.
My car developed a grinding noise on the rear driver's side suspension/brake area. It makes the sound as soon as you move the car, its pretty loud. I don't hear it if the windows are up, but if they are down its definitely noticable. When the car hits around 65mph the ride is fairly bumpy on the freeway, but when I take turns or quick corners, it doesn't get out of control or anything. When I turn the wheel to the left while I drive, the sound isn't quite as loud, but gets louder the further right I turn it, so I don't think its the brakes. I have taken a look but I don't see anything out of place, at the same time I don't know a ton about suspension systems. I will jack it up when I get a chance to look at the control arms back their.
ALSO: In the front passenger side suspension area, I get a light clicking sound while driving, only during movement but when I brake, the sound goes away at very low speeds. As soon as I release the brake it starts back up. Control arm or brakes?
Thanks!
2002 Audi C5 A6 2.7T 148k miles.
Thanks!
Thanks!
Thanks!
Thanks!
Thanks!
Check
Check your brake backing plate…it could have been bent and is touching the rotor or a rock or something got between the plate and the rotor. With the car up in the air spin the rotor and see if you can duplicate the sound. I've even put the car on jackstands and in gear to rotate the wheels. If you do that with the wheels off, make sure you put the lug bolts in (with appropriate washer stacks to avoid the lug bolts locking the hub) to get the hub to turn the rotor.
Thanks for your time and help!
I'm with sloop on the backing plate/ shroud on inboard brake rotor area. That thing is easily tweaked into a bad position by debris getting caught in there. As a precaution, i would also do as sloop said an make sure it's not the bearing, or CV. The boots on CV's can be torn and once that assembly is out of lube, it tends to be very noisy and pretty shaky whilst driving. So, you should address this pronto, as these things snowball into bigger problems and only fix themselves if my old lady is driving it.
As for the front, and body roll questions, not that they are related but could be. Troubleshooting front suspension by describing noises in text is like doing a where's waldo test on the phone. 1.2 Million possibilities and really only 1 answer, so let's not waste our time with the hail mary "it could be the……" statements. You need to get the thing on jackstands and start looking at all the bushings and connections in the suspension. If you are new to this, it's a bit confusing at first, but you will figure it out. With the vehicle "curb weighted" you can check how much play is in each connection and knock out a killer combo of triceps and neck jerking workouts while you investigate your suspension creeks and groans. Whatever you do, don't go to the dealership with the "it's making a sound like WHEEEEEWWWW AAAARRRGGGGHHHH PATEEEWWWEEEE" type of line. Those guys will whip the money out of your hedge fund quicker than you can say "well, i better talk to the wife about financing one of those Q7's first…".
Good luck, we're all counting on you.
Unless your a man of the cloth. With a name like Kinghammer, it's either that or a **** star.
Wheel on properly and torqued up ? with the cahngeover to summer from winters sometimes the centre piece gets corrosion and te wheel dosnt sit square.
Check for a rear broken spring.
Check brake backing plate as mentioned.
See if one of the brake pads hasnt worn off , especially the inside you cant see too well. I find the rear brakes wear out very quickly on this car.
Lastly is the wheel bearing and CV joint.
Work? On Easter? Don't tell me you work for one of them godless, jesus-hating Canadians…… Today is Zombie Jesus day. Where we all should be locked up with the family. Eating swine and arming ourselves with hollow points while we dazzle the nephew with "back when i was in school there…" stories.
