2002 A8 Hub Relacment
Old 04-18-2014, 09:15 AM
proeasy's Avatar
Default 2002 A8 Hub Relacment
Changing the front brakes on my A8, broke off one wheel bolt and others in the hub are close to being stripped. How big of a job to pull the front hubs off? any special tools needed
Thanks
Paul
Old 04-19-2014, 05:24 AM
CJ Miller's Avatar
Thanks
Paul
I believe you can buy a new wheel bearing and hub assembly complete. The assembly bolts on from the inside. You will need to pull the half-shaft and at least one control arm to release the bottom of the strut so you can get the tools in to release the four bolts (triple=square?).
Through Audi they will be pricey; probably 200 or more for each hub and each bearing.
Old 04-21-2014, 05:53 AM
123quattro's Avatar
If you pull the rear lower control arm the half shaft will come out at full steering lock. To remove the bearing you will a triple square bit.
audijim113
08-22-2013 06:15 PM
kgardnez
08-15-2010 09:09 PM
krazylegz
08-08-2006 02:15 AM
QuattroHawk
03-02-2006 05:01 PM
Catamount90
05-02-2003 09:52 AM
Quick Reply: 2002 A8 Hub Relacment
