Where Oh Where is the Water Coming from?
Old 03-01-2014, 09:57 AM
2010GGMQ7's Avatar
Default Where Oh Where is the Water Coming from?
Still fairly new to the forum but have had a few posts. After reading https://www.audiworld.com/forums/sho....php?t=2779964
I'm trying to figure out where to start looking on my 2010 Q7 TDI. I just noticed after a heavy snowstorm and a couple of days later the stain appeared. What puzzles me is the actual color of the stain. Makes me think it is washer fluid that is leaking and maybe not the sunroof drain tubes being clogged.
Old 03-01-2014, 10:03 AM
B490MTL's Avatar
Washer fluid leak, look in you spare tire well and clean up any if there is so you dont fry your electronics.
Old 03-01-2014, 11:59 AM
2010GGMQ7's Avatar
Thank you for such a quick response. I did check the spare tire well and did not find any fluid there. I also checked the surrounding areas around the electronics and didn't find anything wet. Any other suggestions on where I should look next. It would make things much easier if it weren't sooo cold :/
Old 03-01-2014, 01:32 PM
B490MTL's Avatar
Found this guy on youtube, haven't watched the video but I guess its a start.
Old 03-03-2014, 09:03 AM
Buckwheat2088's Avatar
Wow I just discovered the same thing on my Q7 in the same exact spot. WTF. Add this to the list of interior leaks. Already had a sunroof drain replaced (passenger side), now experiencing leaking on driver side....and NOW, purple stains in the rear? Where is the washer fluid coming from????
Old 03-03-2014, 06:54 PM
2010GGMQ7's Avatar
Default Where Oh Where is the Washer fluid coming from?
Glad I'm not the only one but wish I could find the source before any electronics get damaged. If it weren't so darn cold I would have already started taking things apart. But in this cold plactic tabs break really easy :/
Anyone else have this problem? If so, ehat did you do?
Old 03-04-2014, 08:48 AM
arp2nr's Avatar
I have the same issue. Audi tried to do a patch job because in my case there was a crack in the rear washer fluid hose.TO change out this hose the entire headliner would have to be removed, so AUdi tels me Well the patch job didn't work after a few days my rear washer did not work and I was seeing the same stains.
Old 03-05-2014, 07:23 PM
2010GGMQ7's Avatar
Been doing more research and its quite possible that either the hose is cracked or maybe a fitting. Trying to figure out if I should replace stock hose with silicone vacuum hose of the same diameter. From the diagrams I've seen, the crack maybe where the hinge is located. Once it gets warmer I'll have a crack at it and for the meantime won't use the rear washer...
2010DFWA6
08-29-2018 11:06 AM
MB The Body
66
08-11-2006 09:35 PM
philip200qt
11-02-2005 12:41 PM
crappo
07-01-2004 06:56 AM
Wesley Walls
10-28-1999 05:10 AM
Quick Reply: Where Oh Where is the Water Coming from?
