98 A6 Quattro Double Din
Old 02-24-2014, 03:30 PM
madrid09's Avatar
Default 98 A6 Quattro Double Din
Hey guys,
New to the site. I just got an '98 A6 a couple of months ago. I want to convert the center console to a double din for a new stereo. The car currently has Bose speakers. I've found some info on other models on various websites and everyone seems to have a different instructions. I was just wondering if anyone has done a similar job and if they have any insight.
I've attached a picture of what I'm working with.
Thanks for any insight
Old 02-24-2014, 03:35 PM
sounddude's Avatar
Originally Posted by madrid09
Hey guys,
The way I see it there are only two options. You can ditch the climate control and install a custom climate control computer/controller like they use in all the stars cars on TV or you can delete the hazard switch and cup holders and do a ton of cutting. Still not sure that it would fit because I don't know the depth but, unless you have a lot of experience with single to double conversions, you may be biting off more than you can chew.
Old 02-24-2014, 06:16 PM
sounddude's Avatar
The more I think about it, you may be able to drop the climate control/seat heaters down an inch or so. Maybe more because of the able it's cut at. get rid of the trim. (you're going to need to fab something anyway.
I have one of these. (I think mine is a 512)
http://www.kenwoodusa.com/Car_Entert..._Video/KVT-516
It was in an older 944 I bought once and I had it in a BMW for awhile. The only double DIN conversion I ever did was in a 928. About two weeks after I did it someone popped the window and took it. Broke the center console to smitherines. Insurance paid and I carry a $100 deductible so I didn't really loose anything..... Except for $100/a ton of hours of research and even more actual fab work. (lame)
It seems like a lot of work for something that there is already an easy solution for. To each their own but here are my thoughts.
The kenwood single din is the same software as the double DIN (although my 512 lacks delay settings and only has 4 pre-outs meaning no separate sub out... more on this when I do the amp upgrade) the double din Excelon I had came with nav and I had to buy the module (to add nav to my single din. Bluetooth is another 120$ so the 700 or so new price of the single din is not really a savings or an expense compared to the double din). But the double din is at least 300 more. I bought my nav module for 160 on ebay.
Old 02-25-2014, 06:01 AM
madrid09's Avatar
Alright, thanks for your insight. I just think the double din looks so much cleaner.
Old 02-25-2014, 07:01 AM
SloopJohnB@mac.com's Avatar
Hey guys,
First thing you do is replace the OEM speakers with new technology/aftermarket.
I've used Infinity 6030(??) woofers and tweeters in both C5 V8s…YMMV.
The sound difference is stunning when your old speakers are going out and you know it…the difference is noticeable if your speakers are just bugging your wife and she complains so long you change them out. On your old car change out the front and rear speakers.
After that, the head unit changeout might not seem so, ummm, needy.
Old 02-25-2014, 11:01 AM
odoboyusa's Avatar
I agree as well with first replacing the speakers.
I did the same in my 00 a6, replaced front and rears with a/d/s woofer/tweeter pairs and replaced the bose amp with much better sony amps with a built-in equalizer.
The original head unit sounds much better now and I like the stock look.
Old 02-25-2014, 11:45 AM
Prospeeder's Avatar
I dont see why you cant do what A4 guys do and just find the center stack, climate, and if needed center console from 00+ car. Sounds like alot of work for really nothing.
Also i have seen the seat heater switches burn up the seat elements and the switch from being left in an "in between" position for a long time. So set it to an actual number not in between them.
Old 02-25-2014, 02:23 PM
madrid09's Avatar
OK will look into new speakers too.
@Propseeder: Thanks for the heads up
Josh/AWE
Audi A3 / S3 / RS 3 MKII
07-20-2016 07:51 AM
Captain Rossness
26
09-24-2015 05:34 AM
saifxnyc
09-20-2015 11:34 PM
MonSoonHell
09-15-2015 07:14 PM
ECS Tuning-Audi
09-02-2015 11:39 AM
Quick Reply: 98 A6 Quattro Double Din
