Metal Belly Guard and Oil Temparature
Old 02-20-2014, 11:39 AM
A4QuattroV6's Avatar
Default Metal Belly Guard and Oil Temparature
Due to the deep snow, I decided I needed a belly pan to reduce drag in deep snow and protect me from ice and broken chunks of Michigan roads. I couldn't find an oem one and I've seen metal ones online. So I made one out of an old A4 hood I had with the oem dimensions. It turned out really nice, looks really good. In winter, my cars oil temp is right between the 1st and 2nd peg. Now it's just past the second peg. Is this normal? At what peg should I worry? Thanks.
Old 02-20-2014, 12:53 PM
Prospeeder's Avatar
Well you have checked your oil level right. Oil alone does 30% of the cooling of the engine so if its low it will get hotter. Its still in a safe zone and should be just fine. Oil running hot is good, helps boil impurities and moisture out of the oil so it lubricates longer. I would think getting close to 300F is where you would get real worried but if that happened the coolant temp would be extremely high also.
Old 02-20-2014, 04:50 PM
Thanks for the info. I love the metal belly plate btw. Definitely recommend.
ronrevere
3.0TFSI Engine Discussion
9
03-19-2018 08:42 PM
Joejoe8U2
01-21-2016 05:35 PM
ypa814
A6 (C7 Platform) Discussion
09-21-2015 01:18 PM
SWelsch
09-10-2015 05:11 PM
Quick Reply: Metal Belly Guard and Oil Temparature
