Go Back   AudiWorld Forums > Audi Models > Audi A8 / S8 > A8 / S8 (D2 Platform) Discussion
Old 02-17-2014, 01:27 PM   #1
hyperlogos
Account #: 277360
Default AC sprays water from center and only hot air from sides '97A8Q
Subject pretty much says it all. If I set both sides to lo then I get hot air out of everywhere but the center, where I get cool air and eventually little bits of water. Never sounds like running water, though, or splashing. I'm suspecting icing and that the heater valve is never switching off. Do I just need a vag-com to figure this one out, or do I just rebuild or replace something?
hyperlogos is offline   Reply With Quote
Old 02-17-2014, 01:46 PM   #2
silverd2
Account #: 184138
silverd2's Avatar
I'd start by cleaning the interior AC drains...the always seem to clog eventually...that could be the source of the "spray".
http://www.audipages.com/Tech_Articl...tordrains.html
The cool/hot air maybe totally unrelated to the spray ...it may just need a recharge (top off) of refrigerant and/or a VagCom scan for codes (temp flaps/motors, etc...).
Low on refrigerant in these cars usually starts with driver's side (LHD) blowing much warmer than passengers side...worse as refrigerant level goes down.
http://forums.quattroworld.com/a8/msgs/15213.phtml
A VagCom scan will tell you a lot.
Sam
- Post-apocalyptic stunt mechanic....do NOT try this at home, unless you're not a wussy
Mine: '01 A8 SWB
Hers: '03 Allroad 2.7T
Dog's: '90 Passat wagon
silverd2 is online now   Reply With Quote
Old 02-17-2014, 02:10 PM   #3
hyperlogos
Account #: 277360
Well, I will check the drains, but I get FULL HOT air out of everywhere but the center, and I get semi-cooled air from the center. Pretty sure the AC is actually working, and I'm not asking for ANY hot air, so clearly there is something bananas
Forum Jump
