Go Back   AudiWorld Forums > Audi Models > Audi Q3 /Q5 / Q7 > Q5/SQ5 Discussion
Q5/SQ5 Discussion Discussion forum for the Audi Q5 SUV
Sponsored by: Audi
Old 02-14-2014, 04:04 AM   #1
tkd1979
Account #: 163938
Default Flat tire - Problem with collapsible spare
I blew out a tire last week and tried to use the collapsible spare. For whatever reason the spare would not inflate, tried the compressor they give you, took it to multiple gas stations, still no luck..
I did use it once before and it worked fine however, the second time around I couldn't get it inflated. Anyone have any clue why it wouldn't work?
Do you guys know the cost of a replacement or what it may cost to repair?
tkd1979 is offline   Reply With Quote
Old 02-14-2014, 04:25 AM   #2
AudiQ5sleeper
Account #: 235141
question, when you collapse the tire. did you remove the valve pin inside the valve? or did you press the tiny needle to deflate the tire?
AudiQ5sleeper is offline   Reply With Quote
Old 02-14-2014, 07:40 AM   #3
BayGBM
Account #: 151934
I feel your pain. I have had plenty of flats over the years with previous cars but none with the Q5--yet. I still think it is inexcusable for an SUV/Crossover type vehicle to not include a full spare! No donuts and no collapsibles. By definition when you get a flat tire you are in distress. The last thing you should have to think about at that moment is having to inflate some collapsible tire with a compressor that may or may not function correctly. If I could choose to pay a couple hundred dollars more for a Q5 with a full spare in the undercarriage I would readily do so over the current collapsible spare option. Shame on Audi for being so clueless!
BayGBM is offline   Reply With Quote
Old 02-14-2014, 07:53 AM   #4
tkd1979
Account #: 163938
I didn't do it. I believe the tire shop removed the valve pin.
Old 02-14-2014, 08:00 AM   #5
MP4.2+6.0
Senior Member
Account #: 26081
Default Replacement spare can be found on eBay at times
Either the steel rim ones or the earlier alloy ones. Sometimes < = $150, but none currently at a rational price. With my extra winter/summer tire set always around home, I got an alloy one for the Hybrid to keep at the distant vacation home--all we get is a can a goo and the pump. The hybrid battery pack takes over the spare well and storage nook entirely.
Probably the last time your tire was inflated and deflated, the tire bead moved well away from the rim edge and now it's no where close to a seal when you try to air it up. With a high powered air hose, try to get the bead better positioned near the rim edge on both sides to where the air can push it out the last bit and form the seal. Then try a careful deflate, watching carefully where that bead settles and not forcing it away from the rim edges.
Current #1: '06 D3 A8L W12 brilliant black w/ amaretto; 4 seat setup, CPO; modestly lowered, H&R 20mm rear and 12mm front DRs with 275/35 on OEM polished + forged 20's; S8 sway bars (see: rear bar and gen'l D3 bar info and front bar); tweaked 385mm front factory brake mod and matching rear brake mod; matching C6 A6 back headrests (better rear view: headrest tweak); owner installed AMI retrofit with part number details here.
Current #2: 2013 Q5 2.0T hybrid; Scuba blue w/ chestnut sport interior; Euro delivery 7/2013 (pictured at Ingolstadt)
Prior (each modded): 2000 C5 A6 4.2 & '96 C4 A6 2.8Q, both still w/ family; '85 C3 5000S 5 sp FWD; '73 C1 100LS
helpful cross reference to a C6 post with MMI and other TSB's that also cover D3 A8's.
MP4.2+6.0 is offline   Reply With Quote
Old 02-16-2014, 06:48 PM   #6
Redd
Account #: 271985
If you are in north Queens, I'd say to try TM&T. Looks like a hole in the wall station, just west of the Harley Davidson store on the north side of Northern Blvd around 50th? street. Across from the old Pathmark.
They're tire guys and surprisingly good tire guys who have been there for two generations now. If it is something like the valve stem being out, or the tire being off the bead, odds are they'll fix it without ripping you off.
There's only so many reasons that a tire "won't inflate" and anyplace that thinks it is rocket science, should be targeted for a rocket attack.
These odd spares MUST be available unused from the junk yards, after all there is one in each smashed Q5 and not much else uses them, does it?
It followed me home. That's my story and I'm sticking to it.
Redd is offline   Reply With Quote
Forum Jump
